Page 7 of 38 FirstFirst ... 5678917 ... LastLast
Results 61 to 70 of 373
Thread: ebay links
  1. #61
    Difference in robotic terms between low and high density polyethylene?
  2. #62
    Hdpe is significantly stronger but is less flexible than ldpe so parts will probably have to be thicker to compensate.
    It should make decent armour if you allow it room to flex
  3. #63
    ah, i failed :/ i meant to bid for the boards but forgot
  4. #64
  5. #65
    http://cgi.ebay.co.uk/SAFARI-MOBILITY-S ... 500wt_1156
    Definitely want a go of this, but a bit too far away . Could be an ideal heavy base for someone though, could even be a ready made 4WD base for a bot
  6. #66
    Anyone got a transmitter fetish?
    http://cgi.ebay.co.uk/20-ASSORTED-RADIO ... 529wt_1139
    Wonder how many could be converted to 2.4GHz.
  7. #67
    Thing with that scooter is you cant tell if it runs off a single motor or 2 separate ones
  8. #68
    Worth the gamble, if it is one motor you just use it to mess about in. Make it like a remote control pope-mobil
  9. #69
    Solid-state equivalent of a battleswitch, might try one out in Drumroll for the weapon as it eliminates another point of failure (moving parts in a relay that could break):
    http://www.ebay.co.uk/itm/SOLDERLESS-RC ... 862wt_1172
    Also, some 8A (up to 30V) controllers that might be of use in the beetleweight class:
    http://www.ebay.co.uk/itm/RC-BLIMP-Boat ... 493wt_1139
    There are some 2A ones there that I'm going to try for my ant, will see how well they handle.
    Picked up these links a few weeks back on the RW101 forum, just remembered about them now though and figured they'd be worth sharing.
  10. #70
