Page 20 of 38 FirstFirst ... 10181920212230 ... LastLast
Results 191 to 200 of 373
Thread: ebay links
  1. #191
    What a mis-leading photo! Thanks for the heads up.
  2. #192
    is this what your after
    http://www.ebay.co.uk/itm/Range-Rover-P ... 600wt_1270
  3. #193
    i think this is a bosch 35 if anyone's interested
    http://www.ebay.co.uk/itm/180808917745? ... 600wt_1270
  4. #194
    any 1 tryed these ESC out befor
    http://www.ebay.co.uk/itm/130554115725? ... 672wt_1037
  5. #195
    would probably work alright, it won't be 110 amps mind. harry used some even worse '160amp' ones before on 2 12v drill motors and it seemed to work.
  6. #196
    Noticed that earlier, decided to go with the others, but should do the job
  7. #197
    The wire and connectors tells you all you need to know! Those would melt easily at 110amps. I suggest they could probably comfortably handle 10 real amps cont.
  8. #198
    They probably won't have linear ramping forwards and backwards, or even if they do notice the reverse current is rated at 40A (in real terms it's likely to be much less)
  9. #199
    ok thanks for the info i was just seeing if there were any cheaper and as good esc than the 50A boat 1s
  10. #200
