Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 53
Thread: Little spinner 4 upgrades
  1. #41
    Don't tell em Dave! We don't need ls4 to get more powerful.
  2. #42
    Quite a good reading on that chart, although I'm quite suprised your getting issues starting up any faster without higher current spikes. Implies it's more of a timing issue than loading.
    I'll have a look on a few forum's and see what I can find regarding timing for you.
  3. #43
    I did some reading up on it a year or so ago, and remember finding out that scorpion motors like a high timming mode best.... i fiddled with the setting for a while doing spin ups, analysis then moding the software then spinnups again etc... i think it needs to be customised to the robot to get the best performance... i havent bothered with 540, i just left the settings the same as 360... but fiddling around with it did make a massive difference on 360.
    my settings;
    Throttle tab in software;
    vehicle type- airplane
    throttle type- auto calibrate end points
    throttle response- medium (you could probably get away with turning urse up- but 360 span up best set to medium)
    rest of that page should be greyed out.
    Brake tab in softare;
    0% dissabled (obvious reasons lol)
    cut offs tab;
    cutoff voltage - auto lipo 4v per cell
    current limiting - 300a (urse will be different as its a 160 - basicaly i set it the stage below insensative... as that setting had a tendancy to set the esc on fire
    cut off type - hard cut off
    Motor tab (the important one);
    motor start power - high (100)
    motor timing- high (10)
    direction - forward (upto you)
    PWM rate -out runner mode
    other tab;
    power on beep - enabled (i like it)
    BEC voltage-5V
    logging tab;
    every seccond- and i log everything
  4. #44
  5. #45
  6. #46
  7. #47
  8. #48
  9. #49
  10. #50
    Hi Graeme - if you want I have another 4035-560KV here that we can send over for you to try, and I also have another Align motor thats similar power I think and 470KV that I can send as a test too if you want. Not sure if that's any help but let me know and I can get them in the post to you on Monday. Both Brand new so should be running fine.
