£20 for the two scooter wheels and £40 for the four ali wheelsOriginally Posted by harry hills
can you bring to robots live at burgess hill?
Not sure if we'll be there, but could defo drop them off to Aylesbury for someone else to bring for you.Originally Posted by harry hills
i can go to aylesbury( i think) i will take a minumum of 2 then (unsure wether to buy the others as spares)
OK, got some more stuff to go:
Two dump valves suitable for low pressure systems £3.00 each
I have at least one of Trevors regulators for sale. £40, the other is damaged but just trying to find out if trev has any spares for them.
Got a pair of 50mm blue wheels. Would probably do well for a kilobot or something. £3 the pair
Three 19mm ball transfer units - £2.50 each
Type 3000 with 2 fixing holes and a 19mm steel ball.
Maximim loading up 25kg, down 10kg
Max diameter 61mm
Working height of ball 10mm
Under flange to base 12mm
Flange thickness 3.2mm
PCD of mounting holes 44.5mm
Seating hole diameter 29.5
Two 25mm (ish) ball tranfer units - £2.50 each
ill take them little wheels as well![]()
Three 3/8 quick exhaust valves - £5 each
A few boxes of low pressure pneumatic fittings. There is a big box of 12mm fittings, plus other boxes of about 40 10mm, 40 8mm and 40 6mm fittings. I'm not going to list them all - £20 for the lot.
1 x 20bar pressure gauge (very useful for setting regulators and stuff) - £2.50
five 1/4 5/2 valves. four standard ones and one with inlet manifold with 16bar pressure relief valve. I seem to recall this blew last time out but if it works then it's a bonus for you. four with 24v solenoid, one with 12v. Each valve £12each.
Three pressure relief valves. One 11bar, one 16bar and one 20 bar. I've tested these as far as i can with my compressor which due to years of abuse is only giving out about 2.5bar atm. That said, if the don't work you'll get a refund anyway. £8each
