Page 7 of 26 FirstFirst ... 5678917 ... LastLast
Results 61 to 70 of 260
Thread: From The Ground Up (Advice Thread)
  1. #61
  2. #62
  3. #63
    A BEC is not mandatory, but is one less thing to fail. Hence simplicity until is breaks...
    It's best you have a switch for a rx, preferably next to the link. Mainly to stop the battery from draining between the arena and the pits, though partly for safety.
  4. #64
  5. #65
    A picture that large should probably be linked to or I think just uploading it as an attachment and not inserting it will make it smaller.
    If you can get chains/belts you can have the motors diagonally with for example the rear motor powering the left side and the front motor powering the right side.
    You could also try making the robot shorter and wider so its 400mm wide and 256mm long so it will weigh about the same but you will fit in four drill motors far easier with no extra gears
  6. #66
  7. #67
  8. #68
  9. #69
  10. #70
    technobots
    robot market place
