I am going to get the
http://www.giantcod.co.uk/gianitcod-24g ... 03779.html
but it says this about binding:
'The bind procedure is the easiest, quickest, no fuss seen to date, this is done by powering up the transmitter and receiver, then a tiny button positioned at the end of the receiver case is pressed once. A green LED flashes for a second or so then stops, that€™s it, job done!'
and I'm wondering if you press the' tiny button positiond at the end of the receiver case' just for the first binding or every time you bind. if its evry time you bind I will have to change my design![]()
