Hi
After watching rallikas's video, I have some doubt if I can actually make that, as I am not very skilled in that sort of thing. Any other option
Hi
if you want to make a lifter you can make it using some threaded rod a motor, bearings and some arms to lifter another robot with
If you don't need it to have feedback like an ordinary servo so it keeps turning until you centre the stick, then you can replace the potentiometer with a pair of resistors or just apply power to the circuit and tweak it until the motor stops and glue it.
Actually that system is quite simple. Maybe i have to do a build video? :P
Yes, That would be most helpful. I, am not very good at stuff DIY. By the way, What was that thing atached to the motor?
http://www.teamonslaught.fsnet.co.uk/wiring.htm
Team Onslaught used the same method for their steering and have something about it on their website.
If any of the links to other sites on it don't work, try the wayback machine.
I really am USELESSWhat is a potentiometer?
http://en.wikipedia.org/wiki/Potentiometer
:P
Its a sensor that measures how far the servo has turned.
