Hi I have been asking Paul the technical guy from Technobots about a radio fail safe for the new heavy weapon. The reply was.
Failsafe work by detecting (as a minimum) if the pulse width is outside of a 'healthy' signal. Typically this would be say 0.9 to 2.1mS. You need to make sure that your receiver outputs a value that is outside of this range when the transmitter is turned off. Some receiver systems hold last value which means a failsafe would not operate.
Dose the DX5e receiver go out of these limits when the Tx is switched off? I am using the throttle channel
Thanks
Craig
