Originally Posted by
k_c_r
*blows cobwebs away*
Update
It's been a while. RogueTwo Robots stuff took a back seat after the Robots Live event in Edinburgh as most of my focus turned to Scot-Bots stuff. However now that we've got the kits up and running and I'm nearly done making arena walls, I've started turning attention back to my robots.
Just back in from rebuilding Drumroll. After Edinburgh it needed a new baseplate as the 3mm ali chequer-plate was dented and warped, so it got swapped for 3mm steel instead; much sturdier. The GR01s have been removed and traditional drills fitted again. Main reason being that I couldn't get them to run nice and freely ever since I took them apart to clean them out and re-assembled them. If I tightened the screws too much, the gears would rub and grind horribly, and if I loosened them, the ring gear would start to slip - I couldn't seem to find a happy medium. Plus they were so rigid when bolted onto the chassis that shocks probably went straight through them and contributed to the above issues.
Going back to drills gives a bit of flex in the drive setup to reduce shocks and hopefully keep the drives lasting longer. Ultimately though, I think 125mm diameter wheels are at the upper limit for being directly attached to drill shafts. The first Drumroll ran on ~80mm wheels and I barely had to perform maintenance, whereas Drumroll II usually needs drive train maintenance every event. So in future, I'll probably use timing belts and pulleys to transfer drive to a wheel rotating on an axle.
Carcinus is now an empty shell. The chassis is in a poor state after several alterations. Its last run out was at the Scot-Bots Westerton gala day, where it became blindingly obvious (if it wasn't already) that it couldn't do anything when it had a robot in its claws. So in order to be more effective, and to put on more controlled demonstrations at Scot-Bots events, I'm going to be changing it to a grabber/lifter. Got a rough sketch to work to:
[attachment=0:qqkljn5m]P1000057.jpg[/attachment:qqkljn5m]
It uses a GLA-S actuator which will be attached to the lifting mechanism that was in Reaver, pitched at an angle. The entire weapon mech will probably weigh in at around 6kg so it's going to be tight fitting everything else in. Hoping to make some progress on it next week while I'm on holiday.
