It all looks ok on mine. Make sure you've got the latest version and that compatibility mode is turned off.
Sorted, thanks.
0: ERROR_CREATE_SESSIONJLIB_DATABASE_ERROR_FUNCTION_F AILED
comes up for me very occasionally on the home page, has only happened twice in the past 2 days
Same happens to me jonny
I've had this a couple of times too. It's not a serious error and I am debugging to find out what is causing it.
Yup that's what comes up for me, it doesn't seem to do anything serious so im not too worried, was mildly concerning first time i saw it though :P
Everything's been fine here.![]()
Meant to ask: is there a way to access the forum without the series of pictures at the top? Like a specific web address that points directly to the forum without the integration into the main FRA website?
I used to be able to access the old forum on my phone, although it was pretty slow at loading. But now I can't access it at all, due to 'insufficient memory', which I'm guessing is from its attempt to load up the pictures at the top.
Admittedly my phone's not the best out there, but just wondering if there is a simple web-based fix?
Ta muchly![]()
Unfortunately no. However you might want to check your browser options, most enable you to turn off image loading. What phone is it? I might be able to check for that when the template loads and turn off the banner pic across the site.
It's a Samsung C3300k, just a basic low-end smartphone. I'll give the image disabling a try and see how it gets on. No major issue if it still doesn't load, if anything it'll help cut down my procrastination!
Thanks
