Page 22 of 36 FirstFirst ... 12202122232432 ... LastLast
Results 211 to 220 of 356
Thread: Talk to the FRA
  1. #211
    works for me
  2. #212
    Sounds good
    I would probably try to stop this type as it doesn't walk very well
  3. #213
    well surely that should be down to the roboteer to figure out for themselves? The rules should only generally define the mechanism. If someone creates a machine which fits the rule then it should be allowed to run.
    Also how does that one differ to the mechanism in anarchy?
  4. #214
    As you said earlier
    This is the main problem though. If I turn up at an event with a machine that is in essence a cam with a leg attached (skuttle from technogames) am I going to get any weight advantage? I think most people would argue no but then where do we draw the line? Just to clarify I was meaning a very basic cam system for a few kilo. Anything with the complexity of the pilgrim would require a great deal more weight :shock: :shock:
    So in answer to this previous question you asked, I am trying to find consensus as to were the line is drawn. and giving an example of were in my opinion the mechanism dose not come up to specification.
    Anarchy has a system were the leg is actuated by 2 cranks one for leg lift, and another for leg stroke, the example I gave only has the one crank per leg. Hence the walking gait is not that good.
    hope that clears it up for you
  5. #215
    didn't see the lever at the top instead of a crank :blush:
  6. #216
    No problem Gary, I'm glad to have cleared that up.
  7. #217
    Am I right to assume that this will be discussed and a final decision made at the next FRA meeting?
  8. #218
  9. #219
    Quote Originally Posted by Bodge Job
    I think a robot with a shuffel should have some weight advantage
    Why? It's just a wonky wheel.
  10. #220
    I hate to ask this but only managing to get to 1 event this year and never had any real communication from the FRA ever. I was wondering 2011 memberships? Is there a date I should know about?
