Page 19 of 36 FirstFirst ... 9171819202129 ... LastLast
Results 181 to 190 of 356
Thread: Talk to the FRA
  1. #181
    so just to be clear.. what advantage would a shuffle bot get... if any.
    aka drillzilla / whyachi type mechanisms.
  2. #182
    For one, the amount of actual traction on the floor. Drillzilla had such a large footprint on both sides, the gripping surface area on the 4 plates that are in contact with the ground at any one point would be like having 8 wheels worth (just as an example), and they can still have the effectiveness of a rotating wheel in terms of speed (look at how fast Drillzilla moves)
  3. #183
    ... i meant the weight advantage Dave
  4. #184
    Currently, none. Although Craig and I were discussing that there could be a 25-50% weight increase for shuffler walkers and a full 100% for what would be defined as a 'true' walker (which, IMHO, is a walker that displays a walking ability comparible to an animal, insect or human)
  5. #185
    Does the FRA have a proposal for the walker rules?
  6. #186
    kane's Avatar
    Roboteer
    Hi James,
    There is currently no proposed change to the existing rule.
    2.2.
    Legged Robots [Walkers] can weigh up to twice the specified weight in all classes. A
    walker must employ moveable legs to support its weight. Robots with rolling or sliding
    mechanisms will not be classified as walkers.
    However we are more than open to suggestions on how the definition of a walker can be better defined.
    Kane Aston
    http://www.makerobotics.com
    Co-owner and builder of BEHEMOTH
  7. #187
  8. #188
    I think that it should be that if the input to the system turns continuously it's a shuffler regardless of what mechanism you use to walk.
    I would like to put this one to bed for good.
    If you use this argument for walkers what motive force is left? The answer is some type of ram or cylinder,
    There are 3 types pneumatic, Hydraulic or electric
    1/ Pneumatic how much compressed air do you think it would take to run a robot round the arena fighting for 3 minutes? more than a double weight robot can take, that's for sure. EO's think of the cost!!!
    2/ Hydraulic. How slow do you want this robot?
    3/ Electric this one I like! I think that it should be that if the input to the system turns continuously what do you think the ram is powered by ......... a motor
    At what point do you think this continually rotating rule should come in to place???
    The idea is daft, sorry! :shock:
    It won't work, it won't promote diverse types of robots. For example in the last show at Kidderminster how many robots weren't flippers? how about making a rule flippers are only allowed 1kg of gas ( I'm not serious but you get the idea it is not practical)
  9. #189
  10. #190
    kane's Avatar
    Roboteer
    I believe the current rule supports this quite well and is fairly open to interpretation.
    Kane Aston
