Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Anger issues
    OK guys, wired Anger up for the first time today.
    The left hand motor didnt move. The right hand motor accelerated up and just span at a constant speed with no response to the remote. The remote was working cos I could flash the power light on and off.
    I thought I must just have the RC plugs in the wrong place, so I swapped them around a few times, trying different combinations.
    Got it where the right motor was still spinning without any response and the left one was twitching slightly moving the left stick...then the Wotty smoked.
    So I need. A) Some advice and help on what the hell is wrong with it.
    and B) Ian Watts' contact details.
    Ta muchly.
    Check the power feed in, make sure its the correct polarity, thats the only thing i can think of. Ian will be in Dublin until Sunday, so won't be able to get back to you.
    1st thing (apart from the smoke to cheq each drive) just put a battery to each motor just to test each motor 1st ok
    then you will have to make syre you are connected right + and - are ok
    then the watty
    Thanks for the replies. I shall do a complete re-check of everything. On hold for now until I get the Wotty fixed. Have emailed Ian, I'll just wait for when he gets back to me.
    OK, think we've solved it. Basically I was told by 2 other roboteers (I won't name and shame them, lol) that the red plug on the Wotty was the battery one, but now they reakon it's actually the grey one and I had them plugged in the wrong way round. So it wasn't actually my fault.
    Anyway, after the Wotty let off a little smoke, it was still running, but I obviously pulled the link to cut the power pretty sharpish. Is it worth plugging it in again with the plugs the right way round this time to do another test? Or should I get the Wotty checked out first because of the smoke before I try anything with it again?
    Professional opinions please.
    Three other roboteers have said the opposite. If it's already broken, plugging it in again won't damage it, so try it, it might still be working.
    I've had speed controllers and speedo boards smoke before and then work perfectly well afterwards.
  8. #8
    Just tried it again with the plugs the right way round. No smoke or anything, all went ok. Still doesn't work though.
    I have a faint whining noise from the motors, suggesting the power is getting through, but neither responds to the remote. I have 2 lights on the Wotty, one red and one red flashing, and the light in the reciever is also flashing. The power light still responds to the transmitter.
    I didn't get a manual with the Wotty so I don't know what light means what.
    Any advice on that one? Thanks, Dave.
  9. #9
    Dave you have my sympathies.At least we got 1 event out of our new RoboteQ before it packed up.To not even make it to a finished robot stage is bad luck of Stagefright proportions. :shock:
  10. #10
    Ha, Clive, wait til you see it in the arena, it can only get worse! lol
    Have spoken to Mike and Ian via Dave Weston, tried a few things, getting the Wotty sent off soon. It should be all be quite fixable though....apparently. So, fingers crossed, I'm still on for Barnsley (and the rest of the year).
