Page 2 of 11 FirstFirst 1234 ... LastLast
Results 11 to 20 of 110
Thread: first robot
  1. #11
    well if it has a crystal then its definatly not a 2.4ghz
  2. #12
    Sounds like a crystal for a 27MHz unit, which is probably what it will be if it was used for an RC car. To be honest, that will most likely give you very glitchy control over a robot in the arena and you'd be better off buying a new transmitter. They're not as expensive as they used to be; when I started in this hobby I paid £120 for a 40MHz radio system, but now you can get a 2.4GHz transmitter and receiver for £36:
    http://www.sussex-model-centre.co.uk/sh ... p?id=29064
    The 2.4GHz frequency means that you'll not suffer interference in the arena, leading to good control. You also don't need to fit a protruding aerial in your robot either, which is beneficial if you plan to make a robot that can run both ways up
  3. #13
    I agree with Jamie, couldn't recommend going to 2.4ghz more highly. Best decision I ever made.
  4. #14
  5. #15
  6. #16
    Its fairly simple once you see the bits laid out. RC cars don't always work in quite the same way. A good thing to do would be to try and come to an event, any roboteer on this forum would let you have a look inside their machine.
    Put basically though, your basic 2 motor speed controller has a place to attach the 2 motors, either by screw block or solder, and a place to attach the battery, and then leads that plug into your reciever. And that's basically all it is, minus essentials such as removable links and power lights, but they're easy enough.
  7. #17
  8. #18
  9. #19
  10. #20
