hey guys i was wondering if any one could possiby do a render of my bots
heres the list and the stats
Archmage
Weight: 13.6kg
Shape: The same shape as Pillow Torque, except for the lifter which partially sticks out the front.
Colour: Dark blue, with a blood red stripe down the middle.
Dimensions: 47cm x 30cm x10cm
Drive: 2 Astroflight C40 motors, using a 15:1 reduction, powered by a 19.2V 3700mAh NiMh Battlepack.
Locomotion: 4 Pillow Torque-style wheels.
Armour: 3mm titanium
Speed: 10mph
Ground Clearance: 0mm at front. 4mm elsewhere.
Turning Circle: 0m
Weapon: A 4-Bar electric lifter, powered by an Astroflight C90 motor. It can lift 75kg.
Srimech: Invertible, but the lifting arm can self-right it.
Strengths: Fast. Reliable lifter.
Weaknesses: Exposed wheels.
Bio: Lian Walsh's first featherweight design. Essentially Pillow Torque with a new paint job and a 4-bar lifter. Many thanks to Leo Van Miert and Jamie McHarg for helping to fix the stats.
The Servant
Weight: 100kg
Shape: Mute (S7)
Colour: Blood Red
Dimensions: 67cm x 96cm x 26cm
Drive: 4x 24v S28-400 Magmotors powered by 5x NiCad Battlepacks
Locomotion: 4 Mute-style wheels.
Armour: 5mm titanium
Speed: 35mph
Ground Clearance: 0mm at front, 5mm elsewhere.
Turning Circle: 0m
Weapon: A full-pressure rear-hinged Co2 flipper(looks a lot like Chaos 2's) powered by a fire extinguisher using a 70mm bore 100mm stroke ram. It can flip 500kg.
Srimech: Flipper
Strengths: Very fast.
Weaknesses: Untested in battle
Bio: Essentially an updated Mute, Team Blood Mages' Servant is prepared to do some damage
Dr. Thwack
Weight: 100kg
Shape: Biohazard.
Colour: Malachite green
Dimensions: 80cm x 75cm x 10cm
Drive: 4x 24v S28-400 Magmotors, powered by 3x 3000mAh NiCad Battlepacks
Locomotion: El Diablo Grande-style rubber tank tracks.
Armour: 4mm hardox
Speed: 20mph
Ground Clearance: 0mm all around thanks to 3mm titanium skirts. 5mm without skirts.
Turning Circle: 0m
Weapon: A 10kg pneumatic hammer, powered by a fire extinguisher using a 90mm bore 200mm stroke ram. It hits an opponent at 70mph.
Srimech: The hammer.
Strengths: Powerful weapon, nearly unflippable.
that is all thank you, please reply to me if you have the time to do it thank you
