Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 76
Thread: x-mas crazy bots
  1. #41
    ok the draws
    i.a.n vs bandwagon 3
    jinx vs no consequences
    shadow zone forever vs skull
    alexandra sisters vs gabriel v
  2. #42
  3. #43
    lian walsh: ok lets begin the quater finals
    pod 1: bandwagon 3/mark
    pod 2: i.a.n/jack
    3......2.......1.....ACTIVATE
    bandwagon comes racing out of the traps and flips i.a.n on his back but i.a.n self rights and chases bandwagon across
    the arena and flips him but bandwagon self rights fast and pushes i.a.n towards the flame pit but decides to launch it
    across the arena and i.a.n slams into the side wall, bounces into the air as bandwagon comes in to flip it out but
    accidently knocks i.a.n back onto his wheels, now i.a.n gets under bandwagon and flips it again and again and again well
    bandwagon is very resistant to this as it self rights and lauches i.a.n across the arena again and into shunt who axes it
    but i.a.n self rights over the to if shunt and escapes but not from bandwagon, who flips it into growler who grabs him
    and slams i.a.n against the wall with power, and i.a.n gets away but runs straight into bandwagon who hit the pit
    release lauches i.a.n sky high and lands next to the pit, what power by bandwagon who now flips it on its back but i.a.n
    again self rights with great fashion and pushes bandwagon and flips it onto its back but self rights quickly and pushes
    i.a.n into mr psycho who pounds away with its hammer now bandwagon comes in and flips i.a.n near the wall, if it self
    rights itll flip it self out but bandwagon takes advantage and flips it oota
    mark is through to the semi final
    bandwagon 3 could be a contender for the title here with 2 games 2 wins and 2 ootas
    catch you next time on x-mas crazy bots :wink: :shock: :P :twisted: :| :x
  4. #44
    Jinx vs No Consequences
    If NC starts spinning, it's not going to do much. If it tries lifting, it's not going to do much. :P Put the lifter-thingy on the axe head, and lift him over when he's not spinning. Then clamp him and pit him: it's easier to do this when he's upside-down, and his lifter will take him longer to self-right
    Shadow Zone Forever vs Skull
    Right. Had trouble getting to its stats due to a refresh page issue, but it's fixed. Hmm...Nasty weapon, but its drivetrain is weak(ish). I think I can easily get to its sides and push it down the pit. Self-right when needed.
    The Alexandra Sisters: Retribution vs Gabriel V
    ...you bludgering git you.
    First off, AVOID THAT NOSE CONE. Sophitia stalls Gabriel, Cassandra heads for the pit release. Just like before. Then they try and get him down the pit. No OOTAs here, just pit him. Avoid arena walls. I doubt Gabriel can actually make an OOTA but I can't risk it. :P
    There.
  5. #45
    Guest
    Spin up, whack repeatedly until dead. Try to dodge it when it rams so that I can attack the sides or rear instead of the front.
    Good luck Kody
    I think Jinx and Gabriel V will win the other fights.
  6. #46
    Same tactics as last time for the both of them please, let's see what happens :P
  7. #47
    lian walsh: we are back lets get on with it
    pod 1: jinx/kody
    pod 2:no consequences/joey
    3....2....1 activate
    jinx comes into the center of the arena waiting for nc who comes in with its spinning body and charges but jinx dodges
    quickly and nc turns to hit jinx but jinx dodges again and nc hits the wall and stops spinning as jinx hammers away at
    the top of nc now uses the lifting thing on the axe to turn it over and now is bashing the living crap out of the bottom
    of nc who now self rights and jinx slams its axe down and breaks off the lifting on nc, and that impact against the wall
    and the hits from jinx must mean nc cant spin, now jinx smashes through the top armour and now uses the lifter thingy
    to flip nc over now jinx smashes into nc and the lifter thing pulls out a battery, now jinx contiunes to smashes it to hell
    now dead metal comes in on nc with its saw blade BZZZZZZZZZZZZZZZZZZZZT!!!!!! massive slices on the bottom of nc
    as shunt comes after jinx for no reason and the 2 are now having and axe battle against each other its almost like
    killertron vs shunt from rw series 2 but more aggressive now jinx gets its axe into shunt and pulls him over as the refbot
    comes in to count out nc, what a shame for joey 1 2 3 4 5 6 7 8 9 10
    CEASE
    next battles will come soon but im gonna get the main crazy bots updated
  8. #48
    3 2 1 ACTIVATE
    skull gets up to speed with its drum but szf slams it into the wall, now szf pushes it towards the ppz but skull gets away
    from szf who now turns and charges skull at the wall, now it drags back for another go and slams it again and over but
    skull being invertable comes back and is slammed into the wall again by szf who now drags it towards shunt with the
    pickaxe again and again and again, but szf slams skull into the wall now shunt turns its attention to szf who is hit by the
    axe and its wedged inside szf now skull reverses into szf who gets away from shunt and pushes skull into shunt and the
    axe embeds in skull who reverses to close to the pit now szf pushes the 2 bots and the are now dangling over the pit
    who will go in, shunt or skull? shunt doesnt look bothered as skull desperatly tries to get away now szf charges it but
    they both fall into the pit
    after close inspection it is decide that skull fell into the pit 1st so szf proceeds to the semis :P
  9. #49
    w00t
    Battles could be a bit better though (capitalization, length, emphasis). But I won so...
  10. #50
    hold on folks its our last battle of the quaters
    the alexandra sisters vs gabriel v
    3 2 1 activate
    cassandra heads for the pit release as sophitia flips gabriel into the air and back down, now cassandra comes in to
    double team him but gabriel shoves sophitia into the ppz where dead metal is lurking now cassandra tries to rescue its
    sister but is flipped away by gabriel who now flips cassandra over but self rights now it gets under gabriel and sends it
    3 feet into the air and back down on its back but self rights as sophitia gets away from dead metal with a massive cut
    in the side and flips gabriel over but self rights, now gabriel shoves cassandra towards growler who gets her in his jaws
    and power slams it into the wall and lets it go, now all of a sudden all 3 gang up on growler and flip him up against the
    wall and out as the fans cheer loudly, now they turn their attention towards each other now gabriel pushes sophitia on
    the flipper which throws it 10ft into the air and back down and it doesnt look like its moving as refbot comes in to check
    but cassandra flips the ref bot over to stop it counting out its sister but gabriel flips cassandra into growlers jaws upside
    down and cassandras co2 blows as growler drops it down the pit and gabriel pits sophitia CEASE
    semi final draws,
    bandwagon vs jinx
    gabriel v vs shadow zone forever
    battles up tomorrow (possibly if all get tactics in )
