I'm an A-level electronics student, and I'm making a highly ambitious coursework project - A robot. Officiallly it is designed as a search and rescue robot, but the chassis and drivetrain etc are all pretty similar to a combat robot.
The chassis baseplate is 6mm aluminium (50cm square), and the power is two 750W motors (36v).
The front of the robot was originally made of 0.8mm aluminium, but I now realise that this was a bad idea - it is very dented and beaten up after hitting bits and pieces. It does have a steel bar behind it, but it gets dented around this. The aluminium I used was very low grade, and very soft.
I think I should upgrade to stainless steel for the front, to make it more springy and resistant to damage. Remember that this isn't a combat robot - I just don't want it denting if I drive it into something slowly. The robot weighs around 70kg at the moment.
I think I will go for 0.9mm stainless steel (probably from here - however, before buying it I would like your experience and opinion. The two questions are:
- Will I be able to bend it? I rolled the aluminium around some metal tube to get the shape, then screwed it to the (polycarbonate) sides of the chassis.
- Will it be strong enough? I want the strongest stuff that I can easily bend into shape.
I have no idea where 0.9mm steel is on the scale from tin-foil to un-bendable. The curve is about 7.5cm radius.
Any other questions about the robot, feel free to ask!
Many thanks
Andrew
Edit - photos a bit big! Here are the links:
http://img80.imageshack.us/img80/4831/dsc03374a.jpg
http://img137.imageshack.us/img137/2167/dsc03270d.jpg
