Page 14 of 21 FirstFirst ... 41213141516 ... LastLast
Results 131 to 140 of 206
Thread: Starting Point
  1. #131
  2. #132
  3. #133
  4. #134
    http://www.warbotsxtreme.com/motors.htm
    It says there that you multiply the resistance of the motor by the voltage you will use it at.
    Not sure if its correct but it might work.
  5. #135
    Don't bother with a speed controller for the axe, you'll need a switch or relay as you're looking for an instant acceleration. I used these in hornet and they happily handled a magmotor stalled for a few seconds so you should be fine.
    http://www.jaycarelectronics.co.uk/prod ... BCATID=754
    You won't find anything similar cheaper. Couple it along with a battleswitch etc and you'll have you're weapon control system that should happily handle your motor when stalled.
  6. #136
    Quote Originally Posted by daliad100
    Just realised that I misquoted and the edit has gone. It should be Voltage over Resistance gives current.
  7. #137
  8. #138
    Quote Originally Posted by typhoon_driver
    I agree, we've used the same things for our spinners. Be advised that they only close in 1 direction and will pass the current from another direction even when closed. So making an H-bridge out of these is not as simple as normal relays which are either open or closed from both directions.
  9. #139
  10. #140
