Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: 4WD
    Unless you have some exotic drive train then you will only need two channels to drive.
    You can run two motors off of one speed controller but I would check if the controller can take the extra load of another motor so you don't break it.
    Welcome to the forum first
    As a general rule anything that's designed for remote control cars and is rated at aburdly high levels should be avoided, they'll just blow up. The Electronize controllers have a good reputation although you need at least two of them (one per side), while the Sabertooth 2x25A controls both sides in one unit and is quite good in my experience (I wouldn't use it on anything more powerful than drill motors though)
    Everyone has their own recommendation though, based on their own experience, so it's best to ask
    most of us now use a radio system called spektrum these radios have some really good features and are as cheap as some fm stuff
    they only come in a minimum of 3 channels, but those are pricey there are some 5 channel ones cheaper (would you believe)
    you will need some kind of reduction gearbox on any motor
    if you just want to practice and see if this is for you gor the cheaper option of 4 drill motors these have gear boxes attached you see
    decide upon your motors then the contrller to go with them
    alex
  8. #8
    having good 4wd experiance id say, for your first bot, make a nice rectangular base, then get 4 drills from argos (£10 each or so) and mount themto your base. get some blue wheels from james or grant cooper and they just screw onto the drill shaft, then wire the two left motors up to each other, you should have two wires left over, do the same to the other side, buy a speed controller, id recomend tom wilkinsons speed controllers as they are very good and quite cheap, he isnt a big brand though so if he dosent have what you want the electronize speedos ( a different word for speedo is esc btw) ut you wil need 2, wire the wires from the drills into their respective esc/s (one es for each drill if its electronize, one esc for both if its a dual esc) and then plug the other wires coming from te esc into the reiciever. there should be a battery slot coming from the esc, plug your battery into there, well thats my area of knowledge :P ask around for other tips, we dont bite....mostly :P
  9. #9
  10. #10
    yes he is
    he and his brother james cooper run the full combat featherweight show robo challenge
    james:
    memberlist.php?mode=viewprofile&u=881
    grant:
    <a class=postlink-local href=http://www.fightingrobots.co.uk/foru...r /> <br /> oh
