I wish I had a pillar drill at my disposal :P
You can pick up one off ebay for around 60 quid including delivery or if thats too much you can always buy one of these stands
http://cgi.ebay.co.uk/45mm-Collar-Power ... 3a462ed826
and use your regular drill with it. My pillar drill has been one of the most useful tools I ever bought apart from my small lathe and I managed to get it cheap out of B and Q for 35 quid during a sale.
Quick update:
Satanix was back in working order for Maidstone, but we had issues with the controller, for some reason the stick had to be halfway between neutral and full power before one wheel starts moving, which means straight line control is hard. I also had an issue with the wheels, the bolt holding the axle in came loose during its second fight and has come loose during transit. I'm wondering if I should use threadlock to hold it in, but I may wanna be able to break the bond again when I take the unit apart for maintenance.
During my after event check I also found my link wire has come loose, so needs re-soldering, as does my LED wires, as it no longer lights up with the power up.
Stewie burnt out a flipper servo at Maidstone, got a replacement one at £14 cost :S
New version of Baby Hell will soon be on its way, going to 4WD and 11.1v, to up the power by a considerable amout.
I'm also making 4 new robots for the new year; Heretic, my replacement for F.I.N in full combat, it'll be an AW clone of MW champion Hazard, Baby Tilly 2, a re-make of Shanes ant, KillAntron, an AW replica of Killertron to be a run-all-day robot for live events, and finally, As yet unnamed replica of The Saint
More news as it comes
Hey guys
Been a while since I posted, lots gone on since.
the small news first: Due to run in with Variant, I had to get a new battery and new chassis for Stewie, which was kindly milled out for me by ALK engineering (AKA Kenny), I'll be putting it together shortly
The antweight Saint (Whom I've given the working title 'St Jimmy') is coming along well, very hard to fit all the stuff in the cylindrical body :P
I have found out since Wigan that the cause of Satanix's drive issue was the MIXER was not calibrated, so I'll shortly be fixing that, and once it has been, I'll fit the gyro and go about shaving weight
Now the big news, Cabrakan II is on its way, and very quickly thanks to the sterling efforts of Team Xtreme Robotics (Tom Armitage) and his welding skills, making me a pair of beefy motor mounts and a working weapon.
Yes, no more steel chisel, got myself a lifting wedge:
On this video its only on 0.6A 12v trickle charge power, but Tom reliably informs me it can lift his freind with ease, and the lifter is actually rated for 24v, and I'll be running it on 36v.
More news to come
im likeing the lifterbtw, you remember i was making a st replica way back? when its done how about a tag team
Ill test it on voodoos batts. when your running it on 36v it will lift over double that speed.. Ill put voodoo and my mate on the lifter at the same time, That will be way over 100kg then. Ill record it so you can see.
Been a while since I posted on this thing so nows as good a time as any.
Cabrakan:
After a bruising encounter at Norwich the robots chassis is a write off, therefor I am building a brand new one, different construction method, proper motors (a pair of Bosch 750's), and a real weapon (an axe) which was salvaged from Obsidian, some of you may of saw it on the bench at RIAT. That will be tinkered with to provide a full 180 swing rather than the 120 it had before.
Hell's Angel:
After finally getting my ram I am beginning the rebuild of the robot with some assistance from Jason Marsden from Team Bud, should have the robot combat ready by Maidstone or Barnsley at the latest
Satanix:
Just got the robot back after having its electronics and gyro put back in working order (Big Thank you to Geoff Smith for fitting the gyro back in and to the Big Nipper Team for breaking it in the first place:P), still have some work to do on it before the UK champs, namely shave HALF A KILO off the robot, give it a paint job and also find some different tread for the tyres, i don't think the knobbly mountian bike tyres are going to work well in the Robochallenge arena
Antweights:
Stewie is in need of a new top cover after getting a bit chewed up by Truant, and I'll be rebuilding the flipper YET AGAIN, hopefully with a better outcome. Baby Hell was rather hurridly put together for AWS 32, so I am getting the chassis re-done from a 3D printer, hopefully should make the robot stronger in general and get it in the weight limit (had to dremel off a chunk of armour to get it in weight). FIN had a chunk taken out by Millitant at the same event, and so needs a new side plate, but I'm going to rebuild the whole chassis with some thicker material and some better fixings for the 'nails' themselves. The 2 fleaweights will be undergoing rebuilds in the near future, Little Devil is already being rebuilt, however it may be a little overweight so I may have to start again.
Thats the updates for a while, see you again next time![]()
dave, what was wrong with the motors you were using, i know you smoked one in a video i watched in youtube, but seemed to move around alright in the vids i seen.
Hey Ady
The original Cabrakan 1 motors were great, but the end cap of the motors were held in with long M4 bolts, and they snapped and wrecked the windings in the motor, and a replacement for said motor was 300 quid, but Dave Lawrie had some spare ones, which we've used but on the 250mm wheels its just not quick enough to compete with, hence I'm going to change them.
oh rite, looked good in the vids for a first robot
