Page 19 of 26 FirstFirst ... 91718192021 ... LastLast
Results 181 to 190 of 256
Thread: A special Robot Wars Fan Fiction Anniversary
  1. #181
  2. #182
    Decided to venture into this section of the forum. Certainly makes for interesting reading
    I'm not going to start arguing about any results because they make for interesting reading but I thought I would just point out a few small mistakes,
    - T2 has a titanium not a steel shell (mentioned somewhere near the start of thread). 3mm thick titanium with a 2mm thick ali shell 1 inch below that, ie double skinned. The lower steel ring is bolted to the shell by 60 bolts (complete pain to get off I'll tell you!)
    - In terms of tipping T2 over, its very unlikely. The steel ring around the base weighs in at just over 30Kg meaning the centre of gravity is exceptionally low. The gyroscopic effects actually keep the ring spinning in the same plane, ie horizontally even if flipped (whilst spinning) into the air. If you need vertification take a look at the san francisco battle between viscious circle and T2. T2 smacks into the wedge and flies up vertically 3ft but stays completely horizontally. Thats why a proper flip at low speed is needed
    O and if 40Kj hits a hardox spike, its gonna bend. Hardox really isn't all its cracked up to be with the new series of featherweights being able to seriously dent it and in some cases tear through it. In those cases there is around 6KJ involved.
  3. #183
    ...I'd not read too deeply into the fanfic section Gary, for someone of your technical disposition it may be deeply disturbing
  4. #184
  5. #185
    ...that wasn't my point Mark
  6. #186
    Lol always fun to dip into the less financially intense side of roboteering
    Now thats a spinner I would love to have a go of!
  7. #187
    Pfft, a 800kJ walking FBS won VFTs 3 & 4, and PTT3, pretty much destroying everything in its way (heck, Gyrate was even worse if not as successful...8MJs...); it's since been replaced with a translational spinner.
    But yeah, don't take things too too seriously here Gary.
  8. #188
  9. #189
  10. #190
    This one:
    American Oil (Retired)
    Weight: 110kg
    Shape: All Torque (S2), which is a long box with a wedge on the front and back. However, the wedge at the front is extended all the way to the ground. The sides are also slanted 10 degrees inward, like a wedge, to prevent stranding.
    Colour: Chrome with 3 stripes: one red, one white, and one blue running down the middle. The sides are black.
    Dimensions: 85cm x 70cm x 20cm
    Drive: 4 24v S28-400 Magmotors, powered by 6x NiCad Battlepacks.
    Locomotion: 2 70cm x 5cm x 10cm rubber tank tracks.
    Armour: 6.5mm titanium/vanadium alloy
    Speed: 15mph
    Ground Clearance: 0mm at the front due to extended wedge, and at the sides and back due to torsion-sprung 3.5mm titanium skirts. The springs are wrapped around a foam rod to prevent shock damage. 5mm without skirts.
    Turning Circle: 0m
    Weapons: A 750psi rear-hinged flipper with 20 flips mounted on the front, powered by a 2.2kg Co2 tank. The robot uses an 80mm bore 150mm stroke ram, and the rear wedge should prevent me from flipping myself.
    Srimech: The flipper. Luckily, the slightly modified All Torque shape prevents it from being stranded on its side.
    Strength: Tough, uses the 10kg track advantage wisely.
    Weakness: Tracks Controversy
    Bio: Cyrilium returns to the Cyrilium 2 design. I have decided to be possibly stupid and revive it, mostly due to me not properly exploiting the tracks weight advantage. The machine has now been turned back into Cyrilium after I found out that there will be no more new major tournaments for a while.
    Win/Loss Ratio: N/A
