Uh... I think you should change the draws, Mark. No offense or anything, but I'm up against myself.![]()
I can't believe I didn't notice that. However, since I don't want you facing the same bot you went through with...
Round 2 order:
Apocalypse II (3) vs The 2nd Revenge of Black Death (
Tornado vs Envy
no, it doesn not.Originally Posted by corsair_lightning
Gravity 4.5 was the last Gravity to have seen the light. Gravity 5 is a work in progress, gathering parts as we speak
Will probably start contstruction this year, if the house, garden or the feather robot don't take too much time![]()
lol owned
Sorry about that... Well anyways it did get defeated in round 2. Sorry about that whole thing, WJ.
Okay.
Apocalypse 2 VS 2nd Revenge of Black Death
I don't really have any special tactics. I will do my best to avoid the front, get underneath from the sides and flip the darn thing over the fence.
Good luck Liam![]()
Alright, it's time for some round 2 fights...
Our house robots will be Gearcrow and Sgt. Bash.
3..2..1..Activate!!!
And in comes Apocalypse, getting in underneath Black Death. The Bosch 750's of the 8th seed are blatantly overvolted, however that might not be a good idea here, as the motors are straining to outpush the 24v Mags of Apocalypse II. The 3rd seed clearly has more power, as it moves to the side of Black Death and gets underneath. Apocalypse now shoves Black Death into Gearcrow's CPZ, as the claws of the house robot crush into the wheel and motor on the left side of Black Death. Clearly visible smoke is emitted from Black Death, as the disc accidentally hits Gearcrow's lower law, bending it and freeing itself from the CPZ. As Black Death escapes from the CPZ, the damaged motor finally gives out. Apocalypse takes advantage of this, and hits the pit release button, as The Guardian lands next to Black Death, and slowly counts out the 8th seed.
1..2..3..4..5..6..7..8..9..10!
Black Death'll have to come back as The 3rd Revenge of Black Death next time. A hint of advice, Samuel: Replace those 36v Bosch 750s with 24v S28-150 Mags. They're more efficient and last longer in a battle.
APOCALYPSE II (3) MOVES ON TO THE HEAT FINAL!!!
Tornado vs Envy
Our house robots will be Magnavox and Shunt.
For this fight, Tornado will be using the wedge.
And in comes Tornado, immediately charging towards Envy. Shane has learned about powerful ramming robots from his experience in Robot Wars with Trax, as his Mags immediately push forward, surprisingly shoving Tornado back with ease. Pete looks somewhat perplexed as Tornado is shoved into Shunt's CPZ. While the angry house robot axes the Polycarb of the ex-Robot Wars champ, Envy presses the pit release button, and charges into the CPZ, freeing Tornado from Shunt's clutches. Envy takes a blow to the Hardox, as it rams Tornado across the arena... and down into the pit!!!
Tornado has been blown out...
ENVY MOVES ON TO THE HEAT FINAL!!!
So, the heat final:
Apocalypse II (3) vs Envy
What's the point? The fights are barely the length of past PTT intros...
*Cough*Thanks for the criticism...*Cough*
That was an indirect call at you, telling you to MAKE YOUR FIGHTS LONGER.
Perhaps I should have made it so it sounded more constructive, but you've been told this over and over again...
