Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 74
Thread: VRW Series 4
  1. #21
    w00t
    You know my tactics for the rest of the heats, yes?
  2. #22
  3. #23
  4. #24
    boxx: (possible team up sam?) try to avoid the pit and gravity's flipper, get round the back of ant opposition and pit them if it all goes a pit dodge then keep out of harms way :P
  5. #25
    Alright, now who's ready for some round 2 fights?
    Entered by Samuel Park, and seeded number 2, Storm II!!!
    A powerful real robot with a box-wedge and a lifting arm, Storm II hopes to do better then it did last time around.
    (Shows Flashback) And last time, when it was entered by Kody Kunz, it stunned the vapour world by first getting revenge on Typhoon, and then beating veteran Brutalis 2.1. It beat Ramminator Evilution in its semi, before being written out by a judges' decision against Whiplash in the grand final.
    (Shows Other Flashback) And in series 2, it, along with Shredder, defeated Razer and Mousetrap in round 1, defeated Vader in round 2, and annihilated Shredder in the heat final. In the semis, it pitted Series 1 champ Lightning, and defeated Blatant Clone in the grand final eliminator. However, it was pitted by a powerful Coinst in the grand final.
    Entered by Jack Orr, Boxx!!!
    Boxx is a generic robot, a 4WD machine that rams opponents. However, lack of an active weapon could be its downfall.
    Entered by Kody Kunz, Terra the 2nd!!!
    The Titan traitor is back, with a powerful lifting arm and tough armor, however a powerful disc could cause damage to the lifting arm.
    Entered by Harry Orr, Gravity 5!!!
    Probably the most powerful flipper of all time in real life, the flipper has a lot of power, but the machine itself has weak armour.
    (Shows Flashback) And in series 1, it OOTAed Dave Sheppard's Boxy, before being miraculously pitted by Cassius II in round 2.
    And our house robots today will be the 2 dogs of war: Growler and Gripper.
    3..2..1..Activate!!!
    Heat B begins, as Terra immediately gets in behind Gravity, and lifts up with the lifting arm. However, Kody now pushes Gravity under Boxx. Harry presses the flipper button, as Boxx is flung up into the air, crashes down on the arena wall, and falls onto the camera tracks! Storm II rams into the side of Terra, knocking her away from Gravity. Gravity responds by getting under Terra and firing the flipper. The ex-Titan is hurled through the air, as she lands on top of Storm II, who immediately rams forward and lifts, ramming the Titan over the wall to join Boxx.
    Boxx rounded, and Terra the 2nd buried...
    STORM II (2) AND GRAVITY 5 MOVE ON TO ROUND 2!!!
    Entered by Liam Eliot, seed number 7, Brutalis 2.1!!!
    A Dantomkia-shaped bot, this powerful veteran has a low-pressure flipper and tough hardox armour, and has a lot of experience.
    (Shows Flashback) And in the last war, it immobilized Megabyte, before being beaten by Storm II in the heat final.
    (Shows Other Flashback) And in series 2, it flipped and tossed Flirty Skirty and Mauler 5150 about, before being beaten in round 2 by MeCannibal.
    (Shows Other Other Flashback) And in the very first VRW series, it flipped Intrigue and Liar 2 OOTA in round 1, however it was OOTAed in round 2 by Seung Mina III.
    Entered by Pete, Hyper Death IC!!!
    An ancient machine from PTT1 has been revised! Hyper Death now sports a petrol-driven spinning disc and invertibility, however its age is showing, as it hasn't really been updated.
    Entered by Jack Orr, Mythras!!!
    Complex name, simple bot. Mythras is a blue box-wedge with exposed wheels. it was previously named Golden-Eye and had a petrol spinner, but that's been replaced with a tough ramming wedge, however the speed isn't good, the wheels are exposed, and the top might fall off(although it's now bolted down).
    Entered by Kody Kunz, Plunderbird 5!!!
    Quite possibly the worst machine in this melee, P5 sports a wimpy crushing jaw and weak armour. Unfortunately for me, I can't say anything good about it...
    Our house bots will be Magnavox and Cassius Chrome.
    Brutalis by far is the best machine here, and showing it now as it charges into and flips Plunderbird 5 upside-down almost immediately! As P5 sits upside-down, Hyper Death IC slams into the side of Mythras, creating a massive scar along the side. However, Brutalis comes behind Hyper Death, gets under, and flips Pete's machine upside down. That's okay, since it can run inverted, and doing so as it charges towards one of Mythras' wheels, and ripping it right off the motor shaft! Well, that's 3 wheels on the Orr family wagon, as Hyper Death hits Brutalis with the disc, causing a scar on the hardox armour. Mythras is still moving, as it shoves Plunderbird 5 into Magnavox's CPZ, as the flywheel goes to work on P5's bottom panel. Meanwhile, Brutalis has flipped over Mythras, as Hyper Death comes in and rips the wheel on the other side of Mythras away! In the background, as Plunderbird 5 is counted out by The Guardian, Brutalis gets underneath Mythras, and flips it over the stub of an arena wall and onto the camera tracks.
    Plunderbird won't be Plunderfighting for a while, and Mythras went out due to its major shortcoming...
    BRUTALIS 2.1 (7) AND HYPER DEATH IC MOVE ON TO ROUND 2!!!
    Round 2 line-ups:
    Storm II (2) vs Hyper Death IC
    Brutalis 2.1 (7) vs Gravity 5
  6. #26
  7. #27
    Alright, who's ready for some round 2 fights?
    Our house robots will be Gearcrow and Matilda.
    And in comes Storm II, getting in underneath Hyper Death IC, but not before Pete can get in that disc into play! A scar is formed on Storm's front, as it pushes it towards the pit. I think that Sam thinks that the pit is a flame pit, but he won't burn Hyper Death's petrol that easily, since there isn't a flame pit or flamethrower in the arena yet. However, Storm II still has more power then Hyper Death, as it rams the ancient bot into the pit release button. The siren rings, as Storm II rams the PTT round 2 competitor into the pit and out of the competition.
    Hyper Death IC = Holy darn important cr*p...
    STORM II (2) MOVES ON TO THE HEAT FINAL!!!
    Our house robots this time will be Auger Henstrom and Magnavox.
    And in comes the 7th seed, immediately charging towards the side of Gravity. However, in the process, Liam has left his side exposed, as the sharp corner of Gravity smacks into the hardox armour. However, in doing so, He has opened himself up for an attack from Brutalis, who shoves Gravity into Auger Henstrom's CPZ. The drill-forks get underneath Gravity, as Harry does not self-right. He knows that if he self-rights in the corner, then he might go OOTA, and that's apparently a risk he's willing to take, as he fires the flipper... and lands on the camera tracks!!!
    Gravity flies into space...
    BRUTALIS 2.1 (7) GOES THROUGH TO THE HEAT FINAL!!!
    Heat Final:
    Storm II (2) vs Brutalis 2.1 (7)
    Tactics, predictions, etc.
  8. #28
    Boo! You based a house robot name off of one of my house fighters in ATTTWI 2! What are you, a fanboy or something?
    And boo to Terra losing as well. Go Brutalis, I guess.
    10cm high walls - broken arena - broken tourney
  9. #29
  10. #30
