What I meant to say was Bandwagon was on the red line of the CPZ, Mark. Sorry about the rubbish detail of my fights, everyone, but be sure it won't happen again
Well, please look at Steel Avenger vs Tornado vs King B Powerworks. After Tornado was immobilized, Steel Avenger broke off one of King B's wheels. At the end of the fight, it ended up on the red warning line in Matilda's CPZ, and even though it had not entered into the CPZ, Matilda hit it with the flywheel illegally.
That's what it seems like here also. Killalot illegally picked Bandwagon up and tried to pit it, even though it wasn't past the red line.
I'm not asking for a rematch, but I would like it if you would take note of that for future battles.
Just remove the house robots, there is no problems.![]()
This is a tribute for the king of pop, if thats OK
ROUND THREE
From West Yorkshire, N3!
From Vancouver, in Canada, Blue Hurricane!
Roboteers, stand by!
As usual, Joey at the controls of N3 and Samuel with Blue Hurricane.
The house robots are Matilda and Growler.
3-2-1: Activate!
N3 did well in the last round, but has the spinning shell of Blue Hurricane been repaired? Its spinning quite fast, so yes. OH! N3 tried to make its move but got clipped on the side by Blue Hurricane. N3 turns around, only for Blue Hurricane to hit it again, this time spinning it to one side! Now N3 backs into Blue Hurricane, causing sparks, but nothing else. Blue Hurricane gets away, but N3 follows. Joey needs to get hold of Blue Hurricane while it isn't spinning. N3 hits Blue Hurricane with its front beak and pushes it towards the angle grinder! Blue Hurricane trapped, but as N3 brings the forks down, it gets away! Lucky for Samuel there. N3 isn't far behind and gives it another nudge. Sparks fly again. I'm not too sure, but is the beak of N3 damaged from all those hits? It doesn't look like it. This time it avoids Blue Hurricane and presses the pit release button. It backs away...OH! Blue Hurricane struck it from behind and spun it away! N3 regains control and pushes into it. Blue Hurricane spins up again, so N3 needs to avoid that. A good battle by both sides so far. Our newest edition, the house robots, haven't been out so far. N3 hit by Blue Hurricane again, and onto the flame pit! It gets off, but Blue Hurricane takes another go! Gashes and scratches are appearing in the armour of N3, but its still going. It turns around, getting another clip from Blue Hurricane. N3 charges forward, ramming into Blue Hurricane and pushing it aside towards the wall. Blue Hurricane tries to get away, but N3 is holding it there. Its not in a position for the beak to do any damage. Samuel can't do anything. Growler looks on from his CPZ. Will N3 push Blue Hurricane there? No! Its lifting Blue Hurricane up on its forks and dragging it away. Blue Hurricane turned to face the pit! N3 charges and OH! Almost in, but Blue Hurricane fell off the forks and got away. Into the CPZ, though! It escapes as Matilda comes in. N3 gives chase and bashes into it before it can spin up again. Blue Hurricane pushes into the side, but N3 simply brushes it aside and turns to use its beak. Now Blue Hurricane spins, but N3 hits it again before it gets any faster. The last ten seconds count down. Blue Hurricane tries one last shove at N3, but N3 counters its design and slips under again, pushing towards the wall. It won't get it out, though.
Cease!
What a fight. Both robots mobile at the end. So the judges will make their decision.
Blue Hurricane: S: 2 C: 2 D: 3 A: 2 Total: 9
N3: S: 3 C: 3 D: 1 A: 3 Total: 10
Controversial, but N3 goes through to the Grand Final! Well done to them!
Me: Professor Martin Smith, was it a difficult decision to make?
Smith: Yes. Blue Hurricane was damaging, but N3 had the most control, at one point lifting Blue Hurricane up and pushing it against the wall. Controversial, like I said before.
Me: Thank you.
Next, who will join N3 in the final?
Tira VI VS Infusion
See you then![]()
By now, you've probably noticed how slow and short some of my fights are. For the next three weeks, I shall be doing work experience at Jersey Gas, and after work, will probably be too tired and interested in other things to write on here. I wrote this not only as a tribute, but to keep you interested as well. Sorry about that, but once the summer holidays get underway, I'll probably be back to my old self![]()
Don't worry. It's just fine.
Welcome back after a long wait.
ROUND FOUR
From Toronto, in Canada, Tira VI!
From Queensland, in Australia, Infusion!
The Infusion team in booth one, and in booth two, the Tira team.
The house robots are Dead Metal, who is making a first appearance on the show, and Shunt.
3-2-1: Activate!
Two spinning discs. Equals carnage if you ask me. Infusion rushes to the side of Tira, who turns away. They need to avoid that spinning ring on Infusion. Infusion charges, but misses as Tira moves out of the way! Now Tira...OH! It hits the front wedge with the disc. Infusion pushes it aside. Sparks fly as the ring clips Tira's armour, causing a small dent. The wedge of Infusion takes no real damage also. Tira turns around, but Infusion pushes into it with the wedge and towards the flame pit! The disc on Tira is powered by a petrol engine, so it needs to get away from there! OH! The disc rips into the wedge, but Infusion keeps pushing. It backs off, allowing Tira to plan its next move. OUCH! Infusion came in from the side and as it zipped past Tira, made a gash in the armour! Tira turns around, but Infusion gives it another whack! Spinning Tira to one side, but its still mobile, Kody's robot. This time it heads towards the pit release button, but Infusion follows, nudging it a bit. Tira presses the button, ripping it apart as well! Infusion backs ALMOST into the pit. Tira turns to face Infusion, who charges head on. Tira's disc makes a small tear, but nothing more. Its caught in front of Infusion again, allowing Aaron to push it into a CPZ! Tira gets out of there as Shunt comes in. The disc hits the wedge again, causing another tear. Is it coming loose, though? One side looks like its dangling off. Infusion spins around, striking Tira again! Part of the armour seems to have peeled off it at the side on Tira. Infusion gets the wedge under the side and pushes Tira onto the flame pit! OUCH! The spinning ring makes a split in the armour of Tira. It looks like its about to fall off. The disc spins to a stop, and come to think of it, that's not the only thing thats stopped! Did that last impact knock Tira out completley? I think so! Kody can't get it away from the flame pit. Refbot comes in as Infusion pushes Tira into an angle grinder. Tira is immobolised, but they'll have another chance in the playoff.
1-2-3-4-5-6-7-8-9-10!
And now the newest feature to FRFFT, the house robots, can come in to clean up the mess. Shunt hits Tira with his axe and drags it towards the pit. Dead Metal looks on as Shunt moves forward to push Tira into oblivion. Good stuff by Infusion. They go through to the grand final!
Cease!
Tira full of tears and holes, and in the pit.
Infusion moves into the grand final!
So, this is the final lineup
Playoff
Blue Hurricane VS Tira IV
Grand Final
Infusion VS N3
See you then. Sorry about shortness of fight, imagination isn't on my mind at the moment
Blue Hurricane's tactics: Spin up to full speed, and smack right into the disc. When it's disabled, I will just tear it apart like there is no tomorrow.
Good luck Kody.
As for the other battle, I reckon Infusion will win.
Tactics: Uh...get under the toothless (do you see any actual teeth mentioned in Infusion's stats? I didn't last I checked) ring with the forks, lift it, clamp it and pit it. Usual N³ tactics really :P
(it's N³ btw ELLIOT, not N3 as you keep calling it)
Lol, I will put a potato in the exhaust of N3, disabling it completelyOriginally Posted by joeychevron
If N3 tries to start it's motor with the potato in the exhaust and the potato is fired out at great velocities, N3 will be disqualified for having an unteathered projectile
I also see no mention of batteries for an electric starter (do you see any starter mentioned in N3's stats?), so the first decent big hit that stalls the motor will be the end of N3, potato or not
In all seriousness, usual Infusion tactics, spin up, wedge into corner, hit with big spinning thing. Rise, repeat till all N3 is out of your hair.
May the best potato... I mean bot win.
Nuts.
Back into Blue Hurricane, and push/flip him into the wall. Once he's there, rip the hell out of him with the disc.
Good luck.
