Page 6 of 13 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 126
Thread: Crash & Burn: Mini-Tournament of Death 3
  1. #51
  2. #52
    CrOoKeD will get the opponent from the side and flip him OOTA or push him into hazards
    jack
  3. #53
  4. #54
  5. #55
  6. #56
    After 5 days waiting for tactics, the tournament begins! Fasten your seatbelts!
    The Crash & Burn Mini-Tournament of Death 3
    Eliminator 1
    Apocalyse II vs. CrOoKeD
    Team Welsh Warlords bring in the first robot of the tournament, armageddon style! Apocalypse II is a low sloped 4WD box, with a rounded rear, and one hell of an attitude with 9hp on tap and three sets of great tungsten barbs running down the robot from front to back. The real threat, however, is the 4-bar flipper, full pressure with 1.5kg of CO2 and a 120mm x 100mm ram running it. It's also heavily armoured with a 3.2mm monocoque of Hardox, strengthened with 5mm of ti/v alloy in certain areas...however, under the 5mm titanium skirts is a 8mm ground clearance that can be capitalized by some ramming wedges, and only 10 flips in the flipper means that the Apocalypse may never happen.
    Jack Orr barges right in with his team's robot, CrOoKeD! Don't laugh at the weird capitalization, or you'll be flicked out by the CO2-powered flipper this box wedge brings to the table. It's armoured in 6mm Hardox at the front and 6mm titanum at the sides and rear, so it's a tough nut to crack, assuredly. It's got 2WD in the form of MagMotors, go-kart locomotion, and SLA batteries. Its 6mm mild steel chassis is also sturdy, protecting its insides, but the ground clearance around the sides and rear may not give this robot the best manoeuvrability, and with a speed of 20mph, it may prove hard to control as well. Thing is, can CrOoKeD straighten these things out in the warzone, or will the battles leave it warped?
    Roboteers, stand by...
    The house robots are King Leer and Asterix Anarchius. The Watcher is, as always, waiting to count out the competitor who expires first.
    3...
    2...
    1...
    ACTIVATE!
    Mini-tournament, anyone? Like it or not, it's begun again, and it's Liam on the attack first, as Apocalypse swerves around the incoming charge of CrOoKeD and meets the side, almost lazily, as Liam grins! Jack tries to back off, but Liam's already found the side and has snuck under that tiny 2mm ground clearance...but that means CrOoKeD now has enough clearance to get the hell away, and it does so before Apocalypse can take advantage! Once away from Apocalypse, however, CrOoKeD is having a hard time turning. The Welsh robot moves around CrOoKeD easily, getting at the rear of the machine, but CrOoKeD moves straight away! It can go forwards and backwards quite well, but turning seems to be its weak point, and Liam chasing in from behind realizes this all too well, mashing CrOoKeD into the arena wall from the rear, and giving the box wedge a mighty toss! It's unfortunate that CrOoKeD was on an angle however, and Jack's robot flies into the air, in an almost linear trajectory, spinning diagonally, as it comes right back down onto Apocalypse with a rather noisy CRUNCH. It's stuck on the barbs of Apocalypse, and can't get away...and Liam is mightily chuffed by this. He knows he has the advantage, and goes for the pit release button. It's easily struck, but the shock sends CrOoKeD away...almost! CrOoKeD is still hanging off the end of Apocalypse, like a drunkard pinching onto his last pint! Liam, with a rather nasty smirk, backs all the way across the arena, straight towards the pit! But Liam's victory is denied, as with a flick of the flipping arm, CrOoKeD jolts himself off of Apocalypse and out of danger, as APOCALYSE NEARLY GOES DOWN THE PIT HIMSELF! Whoa, what a CLOSE call! Liam was almost tricked into that, but Mr. Low Box isn't going down there just yet.
    CrOoKeD again tries to turn, but still its manoeuvrability is hindered by that too low ground clearance. This means that Apocalypse crashes into the side of CrOoKeD with the force of a rampaging rhinoceros, and slides under with hardly the effort of before! CrOoKeD can't even try to escape like last time, because the barbs have impeded his escape route, which happens to be Apocalypse's own front wedge! Liam doesn't waste any more time. Rather than toy around with his opponent using hazards and house robots, he goes straight to the arena wall and ejects CrOoKeD from the seat of his wedge! CrOoKeD takes flight, bounding over the arena wall like a hurdler, and smashes noisily into the plexiglass beyond the wall, before coming to rest directly onto the camera track below. As the house robots shift angrily, annoyed at their lack of fun this battle, Apocalypse II spins around with its arm raised, and Liam punches his fist into the air with a slight smile, having quickly taken Round 1.
    CEASE!
    Aww, Jack, are you feeling CrOoKeD? There's a curling iron for that.
    Apocalypse II advances to Round 2!
    Next battle: Mornington Crescent vs. Flipping Hell
  7. #57
    Bravo to Liam and yay for Kody!
    C&B:MTOD3
    ROUND 1
    Flipping Hell VS MORNINGTON CRESCENT
    Avoid the flipper at all costs and use my rather nifty manoueverability to attack Flipping Hell's sides and batter it into submission. The two rings should hopefully be able to leave their mark on the alu/steel shell.
  8. #58
  9. #59
  10. #60
    im not CroOkEd kody, just a little DEFLATED
    nice 1 liam iv got some work to do now.....
    jack
