Hi Baz, not sure if you remember us? We did the timing for the first years, but last year they bought that other system which was full of faults.
Thats been ditched now, and we've been hired in by Silverline to create an entire new indoor system including new tracks with steel frames and wooden surfaces, and fully adjustable it will be perfectly flat and straight! It is still 1ft wide and should be a few metres or more longer this year depending on what we can fit into the hall. There is a proper stopping system now aswell, no more worrying about hitting tyres and bails of hay!
We have developed new software and timing systems aswell, which so far have been 100% reliable in thousands of test runs so far. It will display run times, Reaction times and also top speed at the end of the run.
We have some proper traffic lights built in too, when they turn green you will need to press the button on the control box for you dragster to start. Your reaction time will be from when the green light comes on, to when you press the button.
There are some videos of parts of the system floating around somewhere, i'll try and find them!
Sounds like your pulling your finger out on the ride-on I believe the Gadget show will be back again with a really good one so someone to try and beat!
