Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 71
Thread: Martijn's little underdog tournament!
  1. #41
    Destroyed or not, it doesn't really matter...
    Quote Originally Posted by majinb
    ...but only if the robot that didnt make it to the semies is significantly different to the robot that did make it to the semies. For example, Anarchy is accepted (even though 101 reached the semies in the past) yet Cassius 2 isnt (too much like Cassius 1).
    Cassius II was a completely new machine by Rex (the motors, batteries, pneumatics, chassis, etc. were all new, both robots are still displayed side by side semi-regularly at certain events I believe) just like the 'new' Splinter was - allegedly - a completely new machine with new components (although I find it hard to believe every single component couldn't be reused in some form, and roboteers are prolific reusers of parts) yet Marti suggests above that it still wouldn't be allowed due to being too similar, and logic would suggest that Splinter would also be too similar.
    Now, if you were to enter the Splinter duo's previous machine (Ivanhoe) then you'd have more of a case, but I strongly think that Marti would consider both Splinters 'not significantly different' in the same way that both Cassii are 'not significantly different'. You might have an argument but it'd be a very weak one.
  2. #42
  3. #43
  4. #44
  5. #45
  6. #46
  7. #47
  8. #48
  9. #49
    I did :P
    Although I'd be interested in seeing its heat as well...or all of series 5 for that matter...
  10. #50
