Uh...Satanix is Dave's feather, Kody, fail :P
Eye Of Ran AW stats:
Eye Of Ran
WEIGHT: 150g ish (I can throw together a weight calc if you like)
DIMENSIONS: 100 x 80 x 18 mm
SHAPE: A cuboid wider than it is long with a wedge at the back, extending from this cuboid is a long bar, at the end of which is the weapon motor (pic available if this is too difficult to understand, this seems to happen a lot with my designs)
COLOUR: Mostly fantasy artwork, generally blue and green with some gold. The blade is mostly unpainted with viridian tips.
DRIVE: 2 Sanyo 50:1 micro motors driven by a Sabertooth 2x5a controller, driving 2 rear semi-protected rubber tyred wheels, run at 11.1v off a 3 cell lithium polymer pack
SPEED: Medium fast
GROUND CLEARANCE: Blade is about 1-2mm off the ground, all around the rest is quite high except the rear wedge which is 0
ARMOUR: Top plate is a single piece of 3mm polycarb, reinforced with struts of balsa wood to counter the forces of the weapon. The rear wedge is 1mm polycarb covered in spring steel to make it low to the ground, and everything else is either held in with screws or taped to the underside of the top.
WEAPONS: A 65 x 15 x 4 mm undercutting titanium blade, which weighs 30g and is driven by a brushless outrunner motor rated at 20000rpm, with the ends curved into hooks to catch and rip the opposition. The blade protects the front of the robot and the vast majority of the sides as well, and packs a punch of...well, it doesn't particuarly matter in antweights :P It is kept from hitting the ground by a tiny piece of polypropylene in the bottom of the motor.
SRIMECH: Invertible, the odd shape and weapon should prvent it resting on its sides (it doesn't really have any sides anyway)
NOTES: Uses Spektrum radio to prevent it jittering or going out of control.
STRENGTHS: Weaponry, good drive and pushing power
WEAKNESSES: Newtonian physics
