Results 1 to 4 of 4
Thread: 2x Burkets
    We have had loads of problems with Maelstrom's valves recently so we have decided that it is time to replace them.
    So we are looking for 2 burkets (Dad says we need the 5404 ones) or anything similar which can take full pressure.
    Thanks
    Are there 5404's in there? If so, have you tried cleaning them?
    At the moment we have some custom made spool valves which are operated by some smaller pilot valves. recently we have had a lot of trouble with them sticking so we ideally want to replace them with the Burkets.
    Also what is the best way to clean a burket- the one in Aftershock seems to be sticking a bit at the moment so it could probably do with a clean.
    Thanks
    just strip it down and clean all parts make sure there are no (tihs) on the white seal if there is you can swap it round and face the other way
