Results 1 to 4 of 4
Thread: low pressure flipper
    hey,
    what size pipe would be best for a low pressure flipper?
    thanks
    as big as possible is best but i would say 10 - 12mm
    Depends on connector size, if your using a 1.8th port on a valve.. theres no point using 12mm pipe its a waste of weight and space, due to the bore of the connector probably being alot less then the bore of your pipe.. Obviously use the biggest bore connectors on rams/valves etc
    Ive always used this as a guide;
    M5- 4mm pipe
    1/8BSP - 6mm pipe
    1/4BSP - 8mm pipe
    3/8BSP - 10mm pipe
    1/2BSP - 12mm or 14mm pipe
    Keep lengths of pipe and elbows etc to a minimum for best flowrate.
