havent worked with ali sheet before, what thickness base do you recommend for our 6wd fw with electric lifter. i was going to order the 6082 ali sheet from technobots, but unsure what thickness to use.
also is ali easy to cut/drill? or anything i need to be careful with when using it?
thanks
