Results 1 to 8 of 8
Thread: Speed 700 motor help
    sounds like the magnets might of cracked and might be stressing on the armiture
    shock will mostly cause that, i dont think they can be dismantled think there brased together cant remeber tho
    life the tabs on the bottom of the motor then the base comes off and it comes apart
    adrian if you dont want to take it apart urself and it is stiff to turn without being attached to the gearbox, then send it back.
    Put it next to your ear and give it a shake... if it rattles.. its broke As kenny said it is more then likely your magnets have cracked. or the main shaft might of bent depending on your gearbox design.
