The Crashing Bore????? 2?????
*faints*![]()
*faints*![]()
The legend returns!![]()
I am here. Thanks be to Kody for reserving a spot. (If that was ok.
Heavy Weights:
Mobile Failure - http://strickenone.proboards99.com/index.cgi?board=teamaltvapours&action=display&thre ad=507http://strickenone.proboards99.com/i...action=display &thread=507
Bloody Frigid - http://strickenone.proboards99.com/index.cgi?board=teamaltvapours&action=display&thre ad=569http://strickenone.proboards99.com/i...action=display &thread=569
The Featherweight will be along shortly.![]()
Frank can I say that batteries should be along the lines of 6 packs of A123s each pack built to 36v. I think that should be plenty of power and room to fit them. A123s are the kiddy battery at the mo. Soon to be fitted in Thor. Just an opinion you dont have to use them.![]()
Heavyweight 1
Motivation: 4 x 125mm wheels
Speed: 0-12MPH [25MPH under Kinetic Boost]
Clearance: 7.5mm (same inverted) 0mm at the front, the wedge scraps the floor.
Weight: 100kg
Height: 125mm
Length: 800mm
Width: 600mm
Weapon: The weapon is a 28kg Hardox spinning ring (Ala MDU) powered by 2 x D-Pack motors @ 24v (Same motors used in Shredderator). The rim rotates at 2500rpm and should spin up within 1-2 seconds. The weapon is also a storage device for the drive. The spinning rim is connected to each side of the drive via a car air conditioner clutch, when the clutches are engaged, the 31kg kinetic storage bank(the spinning rim) transfers its energy into the drive train, giving it approximately double torque and speed for 2-3 seconds until the rim starts too loose speed and energy. This extra €˜kinetic€™ boost is used to ram into opponents with the front 6mm thick Hardox 500 wedge (similar to the one on Warrior SKF but wider and less depth to it). The front wedge is rubber shock mounted to ensure it survives the biggest of hits.
Drive: 2 x S28-400 Magmotors on 24v geared 4.8:1. The drive is also assisted via the spinning rim as explain above.
Batteries: 12 x 8 A123 cell packs. 26.4V @ 27.6Amp/hour
Armour: Front wedge is made entirely out of 6mm Hardox 500, the top and bottom of the robot is made out of 4mm Hardox 500, The ring is made out of 10mm Hardox 400 with inner bracing to the perimeter bearing. Inner bulk heads are made from 20mm polycarbonate and 10mm aluminium. All internals are mounted on soft urethane mounts for shock protection.
Notes: Invertible, speed when needed and generally well controlled for a spinner. Ram or Spin, Infusion aims to win!
Heavyweight 2
Pictures:http://i20.photobucket.com/albums/b2...Nerix.pngNerix
We might be moving house back home, so I dont feel like doing any writing now.
I will post my entries
Heavyweights:
The Kill Point
Skullcrusher
Featherweights:
Sons of Thunder
(Stats on Chevron Championship 2)
Entry update!
HEAVYWEIGHTS THUS FAR:
1. Seung Mina V (Kody Kunz)
2. Intriguous
3. ??? (Alex McW)
4. ???
5. Gehenna (Andy J)
6. Fissure
7. Under Pressure (Martijn B)
8. Back to Rock III
9. Dervish: The 1337 Generation (Daniel S)
10. Propane Nightmare
11. ??? (Martyn F)
12. ???
13. Orka R.V. (Chris M)
14. Leprosy Infection
15. Eye of Ran II (Joey McC)
16. Nidhogg Evo
17. The Crashing Bore 2 (Frank G)
18. Raging Tempest
19. Tengu VII (Alex H)
20. Achilles
21. Infusion (Aaron K)
22. Nerix
23. Nitro-Gene 5.0 (Paul C)
24. Autoism 3.0
25. BIACS-IS of Evolution (Matt F)
26. Hacked-Off Ha-ka
27. The Kill Point (Elliot S)
28. Skullcrusher
29. Mobile Failure (Tracy F)
30. Bloody Frigid
31. Apocalypse (Liam E)
32. Kill Saw
FEATHERWEIGHTS THUS FAR:
1. Heretic (Kody K)
2. ??? (Alex McW)
3. OverDrive (Andy J)
4. ??? (Martijn B)
5. Deadly Lampshade (Daniel S)
6. ??? (Martyn F)
7. Bulldozer (Chris M)
8. Isolation (Joey McC)
9. ??? (Frank G)
10. Sith (Alex H)
11. M.B.X. (Aaron K)
12. Skink (Paul C)
13. Tidal Wave (Matt F)
14. Sons of Thunder (Elliot S)
15. ??? (Tracy F)
16. Werewolf (Liam E)
Stats required from Alex Mc, Martyn, Chris, Kody (FW), Martijn (FW), Frank (FW) and Tracy (FW).
Sorry you missed out, Shane and Richard. Maybe I could arrange a little grudge match if I have time.
No worries dood![]()
Heretic is done: http://strickenone.proboards99.com/index.cgi?action=display&board=feathers&thread=650 &page=1http://strickenone.proboards99.com/i...feathers&threa d=650&page=1
ORKA RV
Weight: 100 kilos
Body Shape: Basic Invertible box-wedge shape. 1m long, 0.8m wide, 0.3m at maximum height.
Speed: Some 15mph
TC: 0
GC: 8mm, 0mm at front.
Wheels; 6 inner
Armour; 7mm titanium
Power; 3x 12v batteries, powered by S28-400 Magmotors, at 24v.
Weapons; A pneumatic CO2 powered flipping arm that spans most of the robots length. It can throw some 400 kilos and has about 50 flips. Although the arm itself is quite narrow (about half the robot width), the flipper plate expands the full width.
Srimech: Its a both-er. It can run inverted AND self-right using the arm.
Inspiration; Ive always liked Orcas. Adding the K made it sound more dangerous.
Strengths; Weapon
Weaknessess: Hard to turn
LEPROSY INFECTION
Weight; 100 kilos
Body Shape; Invertible box, looks a bit like Tetanus Booster, only slightly larger. About 140cm in length, 90cm in width and 30cm in height.
Speed; 18mph
TC; 0
GC; 6mm. The mini-skirts hang down to about 1mm.
Wheels; 4 inner, top sticking out. Hinged mini-skirts hang from the side, and these protect the wheels from low lying discs.
Power; 3x 12v batteries, powered by S28-400 Magmotors. LEM130 motor for the drum.
Weapons; A very large, very dangerous vertical drum, capable of reaching speeds of 4000rpm. The teeth on the drum are curved upwards so they can flip as well as damage and very sharp at the tip. There is a reason for this explained below. By the drum are two hindged wedge type devices, which drive oppodents onto the drum.
Weaknessess; Wheels may be vulnerable to axes
Bulldozer will come later.
