Results 1 to 10 of 10
Thread: Claw pin
    To secure my claw for my crusher i intend to use a pin however there is no room to push the pin through the sides so i thought about a small path for the pin to follow in order to get the the hole
    i have put some pics online so your clear what i mean
    any help welcomed
    thanks alex
    http://www.flickr.com/photos/27316623http://www.flickr.com/photos/27316623@N06/
    http://www.flickr.com/photos/27316623@N06/>http://www.flickr.com/photos/27316623@N06/
    cant you drill some holes through the sides of the bulkheads so you can push the pin through each bulkheads? inline with the holes for the pin
    i thought about that might be able to fit it in but would be quite tight and difficult
    currently in crumple zone there is a 13mm ti pin that the claw pivots on i want to weld a tube to the claw so the claw wont move around when in battle
    my idea is to have the tube welded on to stop movement then have the old pin running though to secure it in plcae
    the body of the claw is ti and i was wondering what material and size for the tube should i use?
    thanks alex
    washers inbetween the claw and pivot on bulkheads?
    well i thought a tube would help the structure aswell be stronger and less bother taking on and oof than washers
    thaks for posting though kenny
    another question seeing as the claw is ti i can only weld ti to that right?
    thanks alex
    another question seeing as the claw is ti i can only weld ti to that right? - correct
    Ed doesnt that depend on the grades of Ti used?
    if you stuggle at getting some Ti tube for the pin use the washers and get someone to tack and weld the washers together, makes an easy spacer
