The feather weight robot Wedgie has one of the most powerful flippers in Britain, and has fliped out 25 robots in his career. Please tell us if he is powerful enough or if he needs to be up-gunned
If you want to upgun, I have a ram that can do it.
leave him alone,he causes Tiny Toon enough problems as it is already..![]()
Team Toon:
Heavyweight UK Champion 2015
Robot Wars World Annihilator Champion 2015
Heavyweight Tag Team Champion 2012
Featherweight UK Champion 2010
Featherweight Annihilator Champion 2009,2011 & 2014
Rebel Robots Champion 2009
Pika Annihilator Champion (Belgium) 2012
Tanja Trophy Winner 2010
Team Champions ( Team Barbie) 2011
When i was driving Satanix at Nottingham, i stayed WAY clear of Wedgie!
btw, is that 25 robots while in your teams hands alone Andrew?
Andrew you really should push the boat out with Wedgie and invest in a top-of-the-range pneumatic system. It appeared in the Real Robots magazines about six years ago; created by Rex Garrod, it uses a pair of deadly bicycle pump pneumatic rams running through a hi-tech no-expense-spared servo-controlled valve unit that is fed from lightweight uber-high strength plastic fizzy drinks bottles. Such is the safety of this system that it can be run at a previously unheard-of 50 (yes 50!) pounds per square inch! With that sort of system in Wedgie youll be making the arena flipper look like a limp wrist
It was either Wedgie or Explosion that gave Pug a short flight in its first battle at Huddersfield, I was well impressed by how my shell withstood the impact when hitting the ground!
Liam Bryant
Team Bud
Well, if it went out of the arena, or it was seeing stars, it was probably Wedgie! XD
I didnt see who did it, but it was definitly one of the two, Pug was spun in the air when flipped causing me to shout OHYABUGGER!!!!
Liam Bryant
Team Bud
