Results 1 to 8 of 8
Thread: Stainless steel as armour
    we used to use it - but its very heavy especially when using 8mm of the stuff
    1mm not thick enough on its own but with a pastic backing maybe have you thought about mild steel? its a bit lighter?
    how will you cut, fix etc it?
    just read where you are based, so what i wrote seemed pointless
    how ever what plastic are you using?
    (Message edited by psycho fling on October 22, 200
    It will also depend on how you fix the SS to the plastic as any spinners will just rip the SS off the plastic if you dont use a method that spreads the load of the fixing accross the plastic. ie use big washers.
