Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 41
Thread: Locking devices
  1. #31
    I think this is a topic which has been discussed many times.
    Ripper has a locking strap when in the pits, but I remove it before I power up.
    I put link in, tx on, make sure all is well with drives and valves etc... then turn bottles on.
    I cring when I see people arm up their robots with certain locking pins in, they have their robot fully armed and gassed, then lean over to remove the strap or pin. I wouldnt want my head anywhere near a live robot.
    Some even lift their flipper arm to get them out !!
    I must admit, it think your pin is from memory by far the safest ive seen, where when you remove it you are well away from the robot.
    I dont knnow if there is a rule in place whioch donates the correct use of pins, and their removal during arming up.
    I always thought the idea was for in the pits, say for example... a bottle valve has a slight leak and gradually arms the system, the pin will prevent the weapon from firing in the pits.
    Saying that, i always keep my dump valve open when the robot isnt in the arena, and i think if anyone else doesnt, they need to.
    John
    http://www.RoamingRobots.co.ukwww.RoamingRobots.co.uk
  2. #32
    I think it should be made clear that weapons (gas in particular) should be locked at all times until they are armed in the arena for combat.
    Ditto with the dump valve, I only close mine after I,ve put in the link in arena.
  3. #33
    The old Turb did used to misfire sometimes, it happened twice to Dave when he was arming up. It should in theory have fired slowlyish if the valve was open, but it was still lethal if you had got your head in the way. We never had a locking pin for arming up although we did use one in the pits.
    I do use a bar that doesnt require my head anywhere near the weapon itself now. Dump valves should always remain open outside the arena, this is common sense to me.
    The best locking devices are probably Pressure and Maelstrom using a rope to remove the device from a distance.
  4. #34
    this is how beauty has it and it works cus weve left in in during a fight!! lol just a bar through them holes kinda obvious how it works
    http://homepage.ntlworld.com/lichfielduk/ld1.jpghttp://homepage.ntlworld.com/lichfielduk/ld1.jpg
    beast uses 1 this but i dont think weve ever left it in but beast is that well built we only have 1 so jonno doesnt moan at us lol http://homepage.ntlworld.com/lichfielduk/ld2.jpghttp://homepage.ntlworld.com/lichfielduk/ld2.jpg
    (Message edited by john on October 20, 200
  5. #35
    Yeah actually Beautys is fairly good as well, same priciple as mine.
  6. #36
    ok, so what happens if it misfires while your pulling it half out.... your hand will be crushed between the rod and the arena floor !!!
    John
  7. #37
    whenever we have it in while we are arming up we always 4get to take it out anyway! lol
    i cant say anymore cus the fra will start to watch us more often
  8. #38
    Its all about minimising the danger, not stopping it. Its the nature of robot fighting that theres always a possibility for injury.
    I would rather all robots had a system like beautys or LF/LHs to arm and them pull it out. it means theres no chance of missfires when the gas is let in (which some systems is likely). I would rather have 100kg on my hand than the full force of a flipper to the head or arm.Leaving the pin in until the last minute also minimising the time when the flipper is able to fire, so in my view, safer in every way.
    Regarding locking pins for self locking systems is a tricky one that was talked about at a previous meeting.
    I dont believe they need one, and as andy kane pointed out, to have a locking pin actually lock a hydraulic heavyweights crusher you need some beefy I-Beam or similar to stop it - and thats just not reasonable.
    I have not seen a pneumatic robot pass a tech check without a locking pin since that meeting.
  9. #39
  10. #40
    how about crushers? on the fw crushers i have seen in the past i dont remember seeing locking pins obviously the sharp edge protection
    alex
