No Joey, I need 8 peeople so Dan and Jack are both in, just 1 mopre person. And yes Ben its overweight
Shape: A wedge that doesnt quite reach the ground, but instead goes square at the bottom, a rounded rear and a triangular
Colour: Yellow but with eyes and an orange beak and orange scoop
Speed: 19MPH
Weight: 80KG
Armour: 7MM Titanium mmouted with rubber bolts to deflect axes and hammers
Drive: 2 S28-400s magmotors @ 48V
Power: 4 NiCad Battlepacks @ 48V
Locomotion: 2 Inner wheels made of Titanium with a Urethane coating
Turning Circle: 0
Ground Clearance: 0 at front, 4MM everywhere else
Size: 110X90X25 with scoop, 70X70X25 without
Weaponry: A flipper powered by 2 80X110 rams, powered by a 5KG Co2 tank, the arm runs down the s=front of the robot and into a large 2
Srimech: The flipper, the side pyramids, the rounded rear
Notes: may be made into a featherweight one day
Pic: http://www.picoodle.com/view.php?img=/3/9/20/f_InfectedCanm_0e8ce6f.jpg&srv=img2http://www.picoodle.com/view.php?img...f.jpg&srv=img2 8][/URL
and on profile
Ah, elementary maths fail. :P
Still looks a bit borderline to me, but definitely closer to the limit. Perhaps a bit less CO2, you dont really need that much?
Ok change it to a 3KG Co2 tank, might give around 30-35 flips
Entries
1) Kody Kunz
a- Junkyard Mawler
b- Hypno-Disc (S4)
2) Joey McConnell
a- Painkiller
b- Flirty Skirty (S2)
3) Christopher Mason
a- Bad Temper Jr
b- Onslaught (S4, Southern Annihilator)
4) Ben Read
a- Infected Canary
b- Cassius II
5) Samuel Park
a- Wild Thing (S4)
b- Spawn Again (S5)
6) Daniel Stickler
6 days of reservation remaining
7) Jack Orr
1 week of reservation remaining
1 more person to get, and entries from Daniel and Jack to get![]()
BTW Joey, could you either replace Flirty Skirty/give more info/another video because theres not much I can gather from that one![]()
I can do all three if you wish :P
Is MSN working for you at the moment?
no, sorry its not
Ah, right...
You may have a PM on ZED in the next few minutes.
One place left? In!![]()
1. Full-Life Consequences
SHAPE- low skirted box with rounded sides & rear
COLOUR- similar to a headcrab
WEIGHT- 80kg, with any luck
DIMENSIONS- 100cm X 65cm X 30cm
SPEED- 10mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- 15mm without skirts, 0mm with
ARMOUR- 3mm Grade 5 titanium
MOVEMENT- 4 inner wheels
POWER- 2 X 750-watt Bosch motors, running at 36v
WEAPONS- a pair of pneumatic pincers at the front for grappling the opposition. Complementing this is a horizontal Pussycat-style saw blade, powered by a Bosch motor and spinning at 3000rpm.
SRIMECH- invertible. The rounded sides should hopefully prevent it getting beached.
NOTES- flies Scotland flag, inspired by the gut-burstingly hilarious Half-Life badfic of the same name - http://uk.youtube.com/watch?v=OHxyZaZlaOs
STRENGTHS- weapon synergy, excellent pushing power, great acceleration
WEAKNESSES- untested, wheels vulnerable to overhead attacks
PIC- http://img384.imageshack.us/img384/582/fulllifeconsequencesfs1.pnghttp://img384.imageshack.us/img384/5...quencesfs1.png
2. Chaos 2 (RW4)
Hope everythings in order there.
