I want to reserve Cassius II?
I guess the question mark was a typo, lol
thats fine
Entries
1) Kody Kunz
a- Junkyard Mawler
b- Hypno-Disc (S4)
2) Joey McConnell
RESERVED (1 week left)
3) Christopher Mason
4) Ben Read
a- Cassius II
b- ???
5) Samuel Park
a- Wild Thing (S4)
b- ??? (according to Robot Wars: The Ultimate Guide Spawn Again was 84kg going into series 6, so it was probably a similar weight in series 5. Unless I can be proven wrong Samuel must replace this realie)
(Message edited by Swim2win on September 20, 200![]()
Spawn Again...
http://www.youtube.com/watch?v=_spRxbMC5ck
Yeah, its okay, I guess...
I am proven wrong![]()
BAD TEMPER JR
Weight: 80 kilos
Body Shape: Rectangular, long and low. Similar dimensions to Tornado, but not invertible.
Speed: 12mph
TC: 0
GC: 7mm
Wheels: 4 inner
Armour: 6mm titanium
Power: 3x 12v batteries, powered by S28-400 Magmotors, at 24v...the usual.
Colour: Red underbelly, black sides, grey top, white weapon.
Weapon: Pneumatic knife blade, powered by CO2. Theres about 40 odd hits in it. Basically, it looks like someone stuck the blade of Overkill onto the axe arm of Dominator 2.
Srimech: The weapon goes that.
Notes: I have a little Lego model if you need pictures.
Strengths: Persistant.
Weaknessess: The arm is fairly long, so it has to be a distance away to work effectively.
My realie is Onslaught, preferably the S4 version (because of its display in the Annihilator)
Here goes...
Realie: the indestructable, indefatigable and inflatable Flirty Skirty! http://www.youtube.com/watch?v=pqB3I1Jv1kw
Vapour: Painkiller:
WEIGHT: 80kgs
DIMENSIONS: 90 x 70 x 20 cms
SHAPE: Similar to Fluffy in series 5, but with the rear end of Tornado from that period, with the angled plates keeping the wheels in contact with the ground
COLOUR: Mostly either pewter or see through for the polycarb, with some black on the chassis bars and weapon.
DRIVE: 2 S28-400 Magmotors run from 4 NiMh packs at 24v, driving two wheels located towards the rear with urethane rubber tyres for grip. (turning circle is zero)
SPEED: 14mph average, 20mph max
GROUND CLEARANCE: 8mm all around
ARMOUR: Top and bottom are 4mm Hardox, the sides and rear are 10mm polycarbonate supported by rubber shock-absorbing bolts from a steel box section frame connecting the two plates
WEAPONS: The main weapon is a front 60cm diameter Hardox spinning disc run from a redundant chain drive from a Husqvarna 3120XP chainsaw petrol engine, fitted with an expansion tube that allows it to develop about 10hp and with non essential parts removed to save weight. The disc is 15kg in weight, spins at a maximum 4000rpm and delivers about 80kj maximum, with sections cut out to create more of a flywheel effect and reduce the weight.
Also, the entire disc setup can be switched out (losing about 30kg) and the robot can instead be fitted with a second set of identical drive motors and wheels, which make the general shape of the robot more boxy even though little extra armour is added. This setup makes it invertible and 4wd, and has a front scoop made from 3mm aluminium 80cm wide with plates extending forward from the sides to trap things like footballs. The scoop has a clearance of about 5mm at the front, and this entire setup is designed purely for the gauntlet and trials :P
SRIMECH: Runs inverted, and has bars on the side to prevent stranding.
NOTES: Components are shockproofed for protection against itself and other spinners and ramming things, and the engine has heat shields installed to protect it from fire and the other electronics from the heat.
STRENGTHS: Versatile, good weaponry and drive, fairly well armoured
WEAKNESSES: Kody came up with the name
Not bad for something designed in one night I personally feel![]()
Heres my design
Shape: A wedge that doesnt quite reach the ground, but instead goes square at the bottom, a rounded rear and a triangular
Colour: Yellow but with eyes and an orange beak and orange scoop
Speed: 19MPH
Weight: 80KG
Armour: 3.2MM Hardox
Drive: 2 LEM200s @ 60V
Power: 4 NiCad Battlepacks @ 60V
Locomotion: 2 Inner wheels made of Titanium with a Urethane coating
Turning Circle: 0
Ground Clearance: 0 at front, 4MM everywhere else
Size: 110X90X25 with scoop, 70X70X25 without
Weaponry: A flipper powered by 2 80X110 rams, powered by a 5KG Co2 tank, the arm runs down the s=front of the robot and into a large 2
Srimech: The flipper, the side pyramids, the rounded rear
Notes: may be made into a featherweight one day
Pic: http://www.picoodle.com/view.php?img=/3/9/20/f_InfectedCanm_0e8ce6f.jpg&srv=img28http://www.picoodle.com/view.php?img...f.jpg&srv=img2 8][/URL
and on profile
Any spaces left?
Can I reserve a spot?
jack
Dan took the last spot, I think...incidentally, Painkillers disc has two hardened tool steel teeth shaped to bludgeon rather than rip; I managed to leave that bit out of the stats![]()
And Ben, LEM200s weigh at least 10kg each, and youll need at least 35kg for the drive alone, thinking very optimistically...with Hardox armour and a full pressure flipper you might be slightly on the wrong side of the weight limit :P
(Message edited by joeychevron on September 21, 200![]()
