Hydra currently runs on two 36V packs using the sanyo C 3000mAH cells. We had to take one out for the UK champs to make the weight, which was a white knuckle ride even then.
I have four 36V packs using sub C cells (3000mAH). These fit in roughly the same space as the other packs and weigh about the same.
I thought Id ask before I did it if this is a sensible idea to replace them or are they likely to fall over than th larger C cells.
Andy
