And so, we finally reach the semi finals. Four robots have survived all their battles so far, but only one can be the champion - so lets get closer to finding out who it is! Our first semi final battle features two tracked robots: The May Tracks Has You (having beaten Nidhogg, Eternia and Achilles) and System Shock 4.0 (who beat Axe-o-Lotl, Under Pressure and Inferno)!
House Robots: Megaraptor & Drilla Killa Ultimate
3, 2, 1 - ACTIVATE!
As the two tracked robots ran in for the first blow, System Shock 4.0 turned the wrong way as it went for its opponents side, allowing May Tracks to succeed in its own side attack! It pushed System Shock around in a circle for a moment before managing to get its wedge extender under the skirts, and shove System Shock towards Megaraptors CPZ! With a good flip, May Tracks catapulted its opponent straight into the House Robot, who turned and managed to grip System Shock in one claw, before lifting it aloft! As System Shock was dropped unceremoniously, May Tracks was waiting underneath - it moved quickly, ramming System Shock into the arena disc! System Shocks treads took a hit from the disc, but survived! As May Tracks advanced again, System Shock ran for a moment, just managing to keep ahead. Suddenly it stopped, reversed into May Tracks and fired its ramming spikes, shoving its opponent away! System Shock reversed into the side of its stunned opponent and fired the spikes again, but they didnt pierce the Hardox! It was, however, able to shove May Tracks against the wall and pin it!
After about 15 seconds of pinning, System Shock 4.0 fired its spikes again for good measure, but this allowed The May Tracks Has You to slip away! System Shock turned quickly and rammed May Tracks in the side, using its superior power to run it into Drilla Killa Ultimate! Like the ramming spikes, Drilla Killas drills only scratched the resilient Hardox, so it turned to wear away with its rear cone drill! Unfortunately, May Tracks reacted by flipping from under the cone drill! System Shock 4.0 continued to push however, leading to one big pileup in the corner! System Shock was underneath May Trackss skirting, but the combined weight of its opponent and the House Robot proved difficult to lift or move! The comical stalemate went on until System Shock 4.0 was told to back off - when it did, May Tracks gave Drilla Killa Ultimate one more taste of its flipper and rolled to safety! It turned to face the attacking System Shock, resulting in a head on collision! System Shocks drive motors proved superior, and May Tracks was quickly shoved backwards into the arena disc, spinning away, and having to react quickly to avoid System Shock pinning it against the wall!
The tables were suddenly turned, as The May Tracks turned into its reversing opponent and caught it side on again, shoving it into the disc before it could get under the skirt! As System Shock 4.0 was spun away, May Tracks ran after it, but only knocked it as it ran! Another chase ensued, before System Shock 4.0 turned and charged fearlessly! May Tracks tried to turn into its side, but mistimed the turn and missed System Shock again! The ramming robot, meanwhile, reversed into May Tracks and used its spikes once again, but this time May Tracks got out of the way before it could be pinned, and found itself in the perfect position to come in side-on! It shoved System Shock hard until it was under the skirts again, and then it was back to the arena disc! With a flip, System Shock landed on top of the disc, so its tracks and top armour took more damage, but both still held up! It was spun away awkwardly, allowing ample oppotunity for May Tracks to get underneath again, and just flip it against the disc again! System Shock 4.0 landed flat on its treads, now torn a little and leaving it a little wobbly! Before it could get away, May Tracks reappeared and slammed into it, this time ramming it into the pit release! Making sure it was well underneath System Shock 4.0, it carried its opponent to the waiting pit, and itself into the final!
CEASE!
THE MAY TRACKS HAS YOU GOES THROUGH TO THE GRAND FINAL!
Now comes a much anticipated battle between two VFT champions: SoR X (who beat Flaming Hell, The 6isc and Wedginator Devilution) and Wedge Devolution (who beat Walk Dont Run 3 and a Half, Exodus and Troubloon 6)!
House Robots: Assassinator & The Martian
3, 2, 1 - ACTIVATE!
SoR X seemingly came on the attack - but ran right past Wedge Devolution as the flipper tried to turn and catch it, allowing itself to spin up! Wedge Devo threateningly advanced, managing to catch SoR X before it could come in at the side - the rim hit the wedge and side, and both robots parted forcefully! When they ran towards each other again, there was only a glancing blow! Wedge Devolution had ended up close to the pit, so SoR X went for the release! It failed to dodge its opponents front, however, but was only pushed for a moment before the rim hit the wedge again! In the next collision, the two robots became parallel, which only meant another blow for Wedge Devo! However, next time they met head on, and Wedge Devos wedge proved lower! It pushed SoR X right towards the open pit....and just missed! Instead, they hit the wall, and SoR X went skimming off in the wrong direction, hitting another wall on its journey! With its rim slowed, Wedge Devolution was now able to catch it properly, but the pit was now closed, so the nearest available hazard was Assassinator! Wedge Devo slammed SoR X hard into the House Robot, who brought both its axe and spikes into play, in a pileup almost as chaotic as in the previous battle!
In the chaos, SoR X was pushed off Wedge Devolutions wedge and made good its escape - by the time Wedge Devo caught up with it, the rim was spinning again! SoR X slashed across the champs front corner, tearing one end of the skirt! It spun round and tried to bring its flipper into play, but Wedge Devo ran into it head on again and came underneath the wedge! This time, it headed for the arena disc - upon impact, SoR X flew into its opponent, bounced off and went skimming across the floor! With its wedge rather scratched by the experience, Wedge Devo came on the attack, with SoR X aiming for the gap in the skirt. The two robots became parallel - and Wedge Devo was knocked again by the rim! SoR X turned, ran into Wedge Devos side....and the champ found itself experiencing what it had done to so many others, as it flew into the air and landed on its back! When Wedge Devo fired its flipper to selfright, SoR X struck with the rim - it didnt hit the rams, but knocked Wedge Devo for six, sending it tumbling awkwardly onto its wheels!
Wedge Devolution barely had time to think before SoR X hit it again, knocking it into The Martians CPZ! The paintwork on the wedge suffered even more at the hands of The Martians saws! Unfazed, Wedge Devo reversed back into its opponent, knocking itself loose but failing to knock SoR X into the wall! SoR X ran into Wedge Devos side, but couldnt get under the other, intact skirt, and the champion got away! It spun round as SoR X came in, and ran into the rim again, sustaining more damage but slowing it a little! SoR X backed off to spin up again, then reversed, trying to get into Wedge Devos side but failing, although it did land another hit on the front and spin Wedge Devo against the wall! SoR X ran into the undamaged skirt again - it didnt stay undamaged for long, as SoR Xs rim ripped it before Wedge Devo got loose, and charged SoR X into the wall itself! Unfortunately, after bouncing off, SoR X just ran away again to get back up to speed, undoing its opponents efforts! Seeing it move close to the pit, Wedge Devo took a detour and charged the release! Taking a chance, SoR X reversed back into Wedge Devo before it could turn to face it, ripping the left skirt even more! Carried along the side of its opponent, it was able to use the flipper again, neatly overturning it! When Wedge Devo selfrighted, it just landed on top of its opponent! Not wasting the oppotunity, SoR X charged straight at the pit! The VFT6 champion went falling in, with Andy almost driving SoR X in as well, in his excitement!
CEASE!
SoR X GOES THROUGH TO THE GRAND FINAL!
Playoff:
System Shock 4.0 vs Wedge Devolution
Grand Final:
SoR X vs The May Tracks Has You
I particularly enjoyed writing these fights (the playoff and final look like theyre going to be great to write as well), so I hope you all like them too!
(Message edited by velociraptor on November 30, 200![]()
