Results 1 to 5 of 5
Thread: Front ramp material
    im unsure of what material to use for the front ramp to my crusher. most of the ramp is 2mm mild steel and i have designed it in a way that the middle section of the ramp is seperate to these side sections
    this is the section that wil take the force of the claw crushing down
    any help?
    thanks alex
    Guest
    I think Razer had a hole in the front wedge so that it didnt crush itself?
    i will be having the hole in it but this is the section which the claw will go through
    i was planning on welding this middle section if possible to the front triangles
