Page 3 of 10 FirstFirst 12345 ... LastLast
Results 21 to 30 of 92
Thread: New Feather Idea
  1. #21
    The featherweight Battlekits seem to be able to make 2 S28-150s work, to be fair - admittedly they use chains rather than gears, but its not an impossibility.
    I do think though youre not taking reality into account when planning this - you seem to not have made any considerations for budget or indedd practicality.
  2. #22
    Guest
    I think it would be a good bet just to buy 2 cordless drills Ben, then you get the motor, batteries and drive train (?), and its cheaper too
    BTW Joey wahts a featherweight battlekit?
  3. #23
    http://www.robotmarketplace.com/products/battlekits.htmlhttp://www.robotmarketplace.com/prod...attlekits.html
  4. #24
  5. #25
    Have you actually taken into account where youll get the parts for this? Or how youll afford them?
  6. #26
    ben what parts for your feather do you actually have just out of interest. also you said you were going to build a heavyweight robot too so you really have got your work cut out.
  7. #27
  8. #28
  9. #29
  10. #30
    Ben, if you dont have a full machineshop at your disposal, you have a weight/money issue
    Were doing the 1 shop stop in this. Robot marketplace is a suitable webbased shop.
    2 magmotors S28/150. 3.5kg Pricetag £322
    2 gearboxes capable handling the power with a suitable gearratio,
    http://www.robotmarketplace.com/products/TW-TWM3M.html
    Weight 4.4 kg pricetag £492.5
    To get the power to the motors, you need batteries that can deliver at least 200amps without transforming into magic smoke.
    2 sets of the 24V 2400 mAh NiCD Battlepacks should be capable. £133 weight 2.4kg
    For the same weight you can have the NiMH 3300mAh packs, but then you pay £150
    Speedo, Roboteq is going over 100A (and the mag S28/150 can draw up to 280A). £274 weight 1.4 kg
    Grand total. 11.7 kg without wheels and £1222
    To compare, the KOS Astroflight motor/custom build planetairy gearbox/motor in wheel setup with Sidewinder speedo and 13.1V A123 cells is the same pricetag, for 4.5kg all in.
    And the Speed900/MSR gearbox combination with 13.1V A123s and Scorpion XXL speedo is £500 for less than 4 kg.
