Results 1 to 4 of 4
Thread: Ali,Ti,HDPE,Polycarb. Panels Needed
    Hi. im in need of panels cutting for one of my bots. im not too bothered about the material the panels are made from for now as im going to get some Ti panels cut at a later date, Steel cant be used as it takes my robot over weight . I need them pretty quick as i hope to be using the bot at huddersfield. After there cut i still need to drill them and cut a few more holes in and wire up the robot so i could do with them early next week if anyone can help. If not i can go to a fabrication shop on thursday and get them cut it but thought id try here first because they dont have any 6mm ali and they said it could take up to a week which would leave me only one day to do the rest of the cutouts wiring drilling them off. Heres a small drawing of what i need. anything will do for now as long as its the correct thickness.
    http://i189.photobucket.com/albums/z244/TXROBOTICS/Robotics%20Stuff/hooligansizes2.jpghttp://i189.photobucket.com/albums/z...f/hooligansize s2.jpg
    Cheers for any help
    The panels marked 6mm could be 6mm or 5mm. Can anyone help me?
    A jigsaw with a metal working blade would have those done in half a day at most in 5mm ali
