4 left near top of page, the Joey and Daniel Enter = 2
Whatever, its Daves tourney :P
I already reserved a spot.
Meaning there were 4 places before Joey reserved a spot.
3.![]()
LEPROSY INFECTION
Weight; 100 kilos
Body Shape; Tetanus Booster
Speed; 18mph
TC; 0
GC; 6mm
Wheels; 4 inner, top sticking out. Hinged mini-skirts hang from the side, and these protect the wheels from low lying discs.
Armour; 7mm titanium
Power; 3x 12v batteries, powered by S28-400 Magmotors. LEM130 motor for the drum.
Colour; A disgusting shade of lime green.
Weapons; A very large, very dangerous vertical drum, capable of reaching speeds of 4000rpm. The teeth on the drum are curved upwards so they can flip as well as damage and very sharp at the tip. There is a reason for this explained below. By the drum are two hindged wedge type devices, which drive oppodents onto the drum.
Srimech; The robot is invertable. Bars along the side and back prevent stranding. The wheel flaps, both on top and bottom, are set so the robot can still run inverted without getting stranded. Once upside down, the teeth of the drum gouge out robot parts.
Inspiration; Named after the disease which causes the skin to flake and fingers and toes to drop off...namely because the robot does something similar. The basic idea came from an episode of The Simpsons.
Strengths; Drum, control is pretty good
Weaknessess; Wheels may be vulnerable to axes
MEGA MASHER 2
Weight: 100 kilos
Body Shape: Minion with skirts.
Speed: 12mph
TC: 0
GC; 0 at front, 1mm at sides due to skirts, 10mm underneath.
Wheels; 4 inner.
Armour: A nice 3.25mm Hardox
Power: 3x 12v batteries, plus Bosch 750s at 36v.
Colour: Red and yellow.
Weapons; The front is a wedge, and the back has a nasty vertical disc, powered by its own LEM130 motor and spinning at 2000 rpm. It can probably flip as well as damage. A side Minion style bar, pneumatic CO2 powered, comes out from the side.
Srimech: The aforementioned bar rights the robot, even though it can run inverted.
Inspiration; This is probably the only robot I have where I have had no inspiration. It just came as a good name.
Strengths: Power, weaponary
Weaknessess: A little bulky, not as heavy as the body would suggest.
Y4
Weight: 99 kilos
Body Shape: T-Minus
Speed: 16mph
TC: 0
GC: 8mm, but the flipper blade reaches 0.
Wheels: 2 semi outer (that means theyre protected)
Armour: 5mm steel on body, 9mm titanium on wheelguards.
Power: The usual 3x 12v batteries and couple Magmotors (S28-400s) for power.
Colour: Grey
Weapons: An extremely powerful pneumatic CO2 flipper (Try 300 kilos+). Can perform about 30 or so flips before it starts weakening.
Srimech: The flipper acts as srimech. It can also be used as gymnastics. A light flip will knock the robot back over, but pressing hard on the button will send the robot into a 540 degree spin before landing, or a Matador style bound in mid air. All prperly controlled, of course. The robot can also run inverted, so if it gets too close to the arena wall, it should be OK.
Inspiration: A quote from a cartoon. Taz-mania, I believe.
Strengths: Powerful flipper, very entertaining.
Weaknessess: Semi exposed wheels.
1 - Ben R
2 - Franky G
3 - Paul C
4 - Liam
5 - Alex
6 - Kody
7 - Samuel
8 - Twin Bro
9 - Danny S
10 - Steve
11 - AJ
12 - Danny B
13 - Jack O
14 - Joey
15 - Chris
2 spots left, however because I think its a tad unlikely to find 2 more people, I will enter 6 round 1 byes :wink:
My entries for this tournament-with-a-rather-shaky-premise are:
1: STAT
2: Nidhogg
3: Eye of Ran
The statistics can be found on the Team Chevron board on Kodys forum, which you, kind sirs and madams, can find by clicking on his profile.
I wonder if I could get Richard to enter
*thinks*
Would it be OK for me to switch Duncan with Helix please? Stats in same place:
http://strickenone.proboards99.com/index.cgi?board=teamww&action=display&thread=362http://strickenone.proboards99.com/i...isplay&thread= 362
Im very drunk... but if you tell me what Im entering Ill enter...
Yeah, Ill enter, Dave, with Battle Raptor IV, SYNDOS and Tenderizers Revenge 2! (Im planning to update my whole team at some point, but Ill stick with the stats as they are for now.)
BATTLE RAPTOR 4
Weight: 100kg
Shape: Invertable box with wedge at front, rounded sides and rear, painted orange with black stripes like the raptors in Jurassic Park - since theres no room for an aesthetic raptor head, the paint job on the flipper displays a raptor head
Dimensions: 70 x 55 x 30
Speed: 16mph
Ground Clearance: 0 at front due to low wedge, 0 at sides and rear due to skirts
Armour: 4mm Hardox, with holes drilled in it to reduce weight
Wheels: 4, inside robot, poke out the top so the robot can run inverted, uses skid steering
Power: 4 Perm 080s motors on 24V powered by 24V @ 12amp batteries
Weapons: The robot has an pneumatic Atomic-style flipper, with a flipping plate over the wedge at the front (with a plate sticking out of the front and running along the floor for 5cm for getting under skirts) and two bars attached to it that run down either side of the top of the robot to the flipper hinges 3/4 of the way along. At the centre of the top is a titanium electrically powered axe with a Terrorhurtz-style blade. Both weapons work at the front in this version - the flipper is fairly powerful since it is pneumatically powered (about 25 flips per fight), and while the axe isnt as powerful, it should still make a mark, particularly in vulnerable areas like wheels.
Srimech: Flipper and axe can both serve as a srimech (on their own, not together). If weapons fail in resting position, robot can run inverted. Flipper hinges and axe blade fit inside the robot and dont poke out the top, so they dont prop it up.
Tactics: Try to flip opponents, and if I cant, hammer them.
Strengths: Dual weaponry, invertable, manouverable due to skid steering
Weaknesses: Wheels vulnerable to axes, no weapons to attack from rear
SYNDOS (SLICE N DICE ON STEROIDS)
Weight: 96kg
Shape: Invertable box with rounded sides and rear
Dimensions: 60 x 60 x 45
Speed: 12mph
Ground Clearance: 4mm at front, 0 at sides and back due to skirts, skirts are sprung for extra lowness
Armour: 4mm Hardox
Wheels: 2, inside robot, with RC gyro for extra control
Power: 2 Perm 080s motors on 24V powered by 24V @ 12amp batteries
Weapon: 25kg 3000rpm titanium vertical spinning disc at front
Srimech: Invertable
Tactics: Mash with big-a** disc, and try to flip as well.
Strengths: Powerful weapon; low ground clearance
Weaknesses: No weapons on sides and rear; a bit on the slow side
TENDERIZERS REVENGE 2
Weight: 97kg
Shape: Low invertable box with low wedge at the front and inverted wedge at the back - painted blue with its name painted to look like blood on the skirts
Dimensions: 90 x 90 x 20
Speed: 15mph
Ground Clearance: 0 all around due to low wedge and skirts, 2mm behind side skirts, 20cm behind skirt on inverted wedge. Both wedges have skirts attached to them at their edge. The wedge and side skirts are attached to rotatable cylinders inside the robot (or wedge) so they can be moved up and down. When they are down, they are very low and its hard to get underneath, but the robots speed is reduced to 9mph. The side skirts can go up to a point where they work inverted. The skirts on the wedges move within 90 degrees - when their wedge is inverted, they are in a vertical position to repel flippers, and when their wedge is right way up, they are in a horizontal position, riding along the ground to help get under robots. When the robot is moving around normally, all skirts except the front wedge one are pulled down low but not to maximum lowness so it can move quickly - the skirts go to maximum lowness if a flipper comes anywhere near it.
Armour: Main body has 5mm polycarbonate on top of 5mm titanium, skirts are 4mm titanium, wedges are 5mm hardox
Weapon: An electrically powered lifting arm, which runs along half of the top of the robot - its tip is pointed to help hold onto robots, and is at the point where the wedge meets the body, and it does not go down the wedge. It can rotate through 360 degrees so it can be used when the robot is inverted.
Srimech: Invertable - arm will act as srimech, but this will hardly happen as the robot works identically both ways up. Moveable skirts prevent it from resting on its sides.
Tactics: Run into opponents, try to get under them, then get them onto its top and onto the arm. The arm turns them over, or catches them so I can carry them around.
Strengths: Decent pushing power; moveable skirts; difficult to attack by flippers
Weaknesses: May struggle to use arm against some opponents
(Message edited by velociraptor on September 14, 200![]()
