Good Good.
I havent forgotten about this, Im not going to any work until the grudge matches have ended and I havent had the time to do the remaining matches yet.
Although I might try and do them this weekend
Good Good.
Is there a spot for me?
If so, I hereby reserve it
hi
i have already reserved a spot but did not post any stats... so here they are...
Shape:box wedge,dimensions are,1m long,0.75m wide and 0.5m high at the back.
Chassis:6mm mild steel
Armor:6mm hardox(f)6mm ti(b+s)
Weapon:a co2 full pressure flipper at 750psi with 1 110mm ram,and a 2kg bottle,the arm is hinged at the back and made of 8mm mild steel
Battery:2x 12v slas wired in series
Motors:2x magmoters at24v
weight:98kgs
Wheels:2x go-cart wheels
Ground clearance:0mm at the front,and 2mm at the sides and the back
Speed:10mph
Turning circle:0m
Shape: A box, Dimensions are:1m(L)0.6m(W)and 0.3m(H)
wheels:4 go-cart wheels
Drive:2 lem130s
Batteries:3 sla€™s wired in series
Chassis:8mm titanium
Armor:15mm titanium wedge on the front, 6mm titanium on the back,12mm titanium the sides and 8mm titanium on the top
Weaponusher, with 2 static spikes made out of 5mm mild steel either side of the Wedge.
Weight:98kgs
Ground clearance:0mm on the front,2mm at the back + sides
Top speed:15mph
Strength: fast , good pushing power, invertable
Weakness: when flipped over it has a high ground clearance at the front
Name: pick-axe of doom
Shape: box wedge
number of wheels: 2 go-cart wheels
Drive: 2 lem130€™s
Armor: 9mm polycarb for the front/back, 7mm polycarb on the top and 8mm ti on the sides
Chassis: 8mm mild steel
Weapon: 5mm steel tubing(0.6m long) with a 8mm ti axe head(10cm long)powered by a 2kg c02 tank at 750psi with 1 100mm ram
Dimensions: 0.9m long, 0.75m wide and 0.5m high at the back
Top speed: 5mph
Ground clearance: 0mm at the front 2mm at the back and 2mm at the sides
Batteries: 2 12v sealed-lead-acid wired in series
Weakness: easy to hit with other axes
Strength: can self right with the axe
jack
Yep, there is a spot for you.
Ok, my entries!![]()
1) Requiem (not the new one, the 100kg one)
2) Pure Evil: Back To Basics
3) Supreme
Stats here - http://strickenone.proboards99.com/index.cgi?board=teambvhttp://strickenone.proboards99.com/i...i?board=teambv
Is there still a spot open? I might as well enter if there is.
I count 4 spots left
I count 2
Then you cant count![]()
Funnily I count 3. :S
