Glad to see Leo's still around.![]()
Raise the dead
shape:see pic
dimensions: 750mm x 500mm x 210mm
weight:100kg
wheels: 2 x 220mm custom wheels, rubber tyre
clearance: 0mm at front and skirts, 6mm at back (exc. skirt)
motors: 2 x LEM 130's
speed:15mph
armour: 6mmvti/v alloy, 7mm front of lifter, 4mm at end of skirts
weapon: 1000psi CO2 4-bar flipper powered by a 190mm ram and a 3kg CO2 bottle.
srimech: invertible, may be able to self right with flipper
So back to vapourbot designing, i have tweaked my two original vapours:
Shape : Plowed Box, like Punjar,but with sides and back sloped at 45° angle, with a slot cut in the plowed front for the weapon
Dimensions : Length : 60 cm,Width : 80 cm Height : 35cm
Color : Dark Blue
Weight : 99kg
Movement : 2 Go-Kart wheels
Motors : 2 NPC-T74 at 36V
Speed : 20 Mph
Armor : 4mm Hardox for everythingexcept the front plow which is 1mm thinner
Turning circle : 0mm
Ground Clearance : 1,5cm
Power : 6 Ni-Cad battlepacks at36V
Weapon : A Vertical ElectricBoogaloo style bar , powered by an Perm 132 at 36V, allowing it toreach 3000RPM
Shape : Low Box, Tornado Style,with a plow at back, and a Last Rites style cage holding the weaponat the front
Dimensions : Length : 90 cm,Large : 80 cm Height : 35cm
Color : Blood Red
Weight : 100kg
Movement : 2 Caterpillar Tracks
Motors : 2 NPC-T74 at 24V
Speed : 15 Mph
Armor : 3mm Hardox
Weapon : A Matilda Style 27kgFlywheel with 2 S7 Tool Steel Series 4 Hypno-disc like teeth, poweredby an E-tek R at 36V, allowing it to reach 3000RPM
New Vapour whipped up
Weight: 100kg
Shape : Box Shape, with roudedsides and a back slot for the secondary weapon
Drive : 4 Go-Kart Wheels, drivenby 4 NPC-41250 at 24V
Armor : 2.5 mm Hardox
Colour : Golden, with the name inRed on the top and bottom
Length : 80cm
Width : 60cm
Height : 30cm
Speed : 20mph
Srimech : Invertible
Ground Clearance : 1cm
Weapons : A hinged wedge at the front, which therefore means it will always scrape the floor, made of 3mm Hardox , wedge works the same either way up, and 2small teeth can be mounted at the top, near the edges for preventopponents from jumping over it, the wedge is 20 cm long and has thesame witdh and height as the chassis, with a 35° slope
A horisontal spinning disc 45 cm wideand 5 cm tall, with 2 Hypno-Disc Series 4 teeth, spinning at 2500RPM, powered by an E-Tek at 36V
Turing Circle : None
I'm still a little unsure about this sort of thing, with the weights, dimensions and such like. Does this one look like it would work?
Robot Name: No Exit
Shape: Rounded cylinder segment (See image)
Weight: 27.0 kg
Length: 29.9 cm, 24.5 cm with Ramp weapon
Width: 30.0 cm
Height: 5.5 cm
Motivation: 2x solid rubber & polyurethane wheels
Drive: 2x DeWalt 12V New Style Drill Motors
Power: 1x 14.8V Li-Poly 4-cell pack
Armour: 4mm Kevlar and fiberglass shell with Nomex lining, 6.5mm Titanium frame & wedges
Weaponry: CO2 powered low-pressure Flipping arm with interchangeable Titanium wedge and Hardox Ramp attachments, hinged titanium wedges, actuated HDPE bollards
Speed: 14.5 mph
Turning Circle: 0 cm
Ground Clearance: 5 mm, 0mm for wedges
Srimech: Flipping Arm
Colour: Near-black, details based on road markings (See image)
