Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Hmmmm
    envy seems to have a problem and i cant put my finger on it so i will ask to see if anyone has had similar probs.
    there doesnt seem to be any ooomph. it goes ok till there is weight in the robot then it seems sluggish. i have tested the motors and they seem fine. the batteries are charging ok too. could the roboteq reset itself to a different setting perhaps current limiting itself? would the gyro be making any difference? the gyro is plugged in ok but i wonder if they can make a difference if failing. i will plug in the roboteq to see what the settings are and plan to run at portsmouth without the gyro. but any input would be nice please.
    the batteries charge up to 3000ah give or take a little but mostly give. i.e. 3100ah, and the volts read 29v sometimes 30v. the batteries are old ones but seem ok. the problems have been there ever since turb flipped envy at guildford and a lot of the wiring came out because i hadnt tied them down from the trip to Doha. i have been told that the roboteq can still run if a couple of fets are gone but will limit the current. i will take it to bits and check that too.
    ive found with nicsds there performance slowly gets worse n worse.. try borrowing a brand new set of someone- or ask them to try your packs in there robot to see if they notice a differance.
    I agree with Woody and Dave. I have the same problem since we built Turb mk2 last year it has never been as fast as the old one even though non of the drive system has changed. I assume that the batteries are going down the pan slowly. Like yours Shane the easily take 3000mAh and have sufficient voltage. But they do loose the ability to give out high currents a few hours after charging.
    hmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm
    i will check over the roboteq just to make sure then try and get some new packs. they are old packs and if you have had the same prob then odds on its that. some new packs wouldnt go a miss anyway. just a few hundred quid needed now. spent up on featherweight
    changing the subject slightly but keeping it with the same robots, any pictures of your feather weight Shane?
  8. #8
  9. #9
  10. #10
    I would say none on those have the discharge needed for a heavyweight. I would stick with tried and tested batteries for a first heavy, i.e. hawkers or bot-packs. Both being expensive, but probably better in the long run.
