paul, if youd be so kind to PLEASE anwer my question, I asked it only 4 times so I understand its easy to overlook, but still...
(Message edited by MajinB on June 16, 200![]()
And what question would that be Martijn?
I dont believe theres a bigger font available than the one I used last time...
anyway
verdanaarialhelvetica>+2>are you gonna concentrate on this or on the Challenge Belt first Paul?
in other words, if you finish the challenge belt first, reserve me a spot
Ah, I have the solution for that:
http://www.insaneclown.nl/vapourbots/paul.phphttp://www.insaneclown.nl/vapourbots/paul.php
Leo, Marti...![]()
PAUL.
+2>STOP DODGING MARTIJNS QUESTION.
Name: Revenge of the Zombie 2
Shape: Cross shape box with rounded back and has 4 TI spikes on robot 2 in the middle of robot and the other 2 on the back for ramming
Speed: 20MPH
Weight:220lb (100KG)
Armour: 5mm Titanium
Chassis: Titanium
Drive Motor: 2 x LEM130 Lynch Motor
Power: 4 x 30cell 36v 3Ah Sanyo NiCad Packs
Motivation: 4 Nightmare style tires w/ welded TI spikes
Turning Circle: 0
Dimension in CM (Length x Wide x HeightUnknown
Weaponry: Bulldozer blade on the front made out of Titanium w/ 2 raptor claws on top (to give it a meaner look)and a Pneumatic axe powered by a 4kg liquid CO2 dual high-flow CO2 regulator 250mm stroke, 100mm bore pneumatic cylinder develops 900kg of force and 2300 joules of energy direct rack-and-pinion drive 5 liter buffer tank
Strenght: Revenge of Zombie 2 has the speed and Push ability of Storm 2 and has one of the most powerful axe
Weakness: Hates powerful Spinners
Self-Righter: Axe
Note: Revenge of Zombie has 3 interchangeable axe heads made out of S7 Tool Steel
Name: Texas Chainsaw Massacre 2
Shape: Sewer Snake (new version lifter)
Colour: Grey
Speed: 28MPH
Weight: 220lb (100kg)
Armour: 6mm TI
Chassis: Titanium
Drive: 4 LEM 130s
Power: 4 12v battlepacks giving 48 volts total
Motivation: 6 Battle Tread Carefree Wheels
Ground Clearance: 0mm on the front 5mm on both sides and 0mm on back
Turning Circle: Zilch
Dimensions in CM (LxWxH): 1,14 x 76 x 46m
Weaponry: Lifting Tusk powered by a 7hp 2-stroke STIHL disc cutter engine the tusk is made from S7 Tool Steel and heat treated to give it maximum strength and can lift 500-800kg up to 1.2 meters about the ground
Self-Righter: Invertible
Strengths: Powerful Lifter good armour, speed
Weakness: exposed wheels
Name: Psycho Killer 2
Shape Tornado (RW 7)
Colour: black
Speed: 24MPH
Armour: 6mm TI
Chassis: Titanium
Drive: 2 x LEM130 at 36v.
Power: 6 NiCad Battle Packs at 36v
Motivation: 2 TI Tracks w/ 1inch custom made raptor claw for grip (inside of the robot)
Ground Clearance: 0mm on the front 1mm on both sides and 1mm on back
Dimensions in CM (Length x Height x Wide) 75cm x65cm 20cm
Weaponry: crushing/lifting claw powered by a modified chainsaw engine driving a hydraulic pump at 2000psi it also has 2 custom made TI wedge on front to help get its opponents to the weapon with ease.
Self-Righter: invertible but can self right with weapon
Strengths: Powerful lifter, good armour and speed
Weakness: Hates spinners
Name: The Grudge 1
Shape: Suicidal Tendencies
Colour: Black
Speed: 18MPH
Armour: 6mm TI
Chassis: Titanium
Drive: 2 x S28-400 Magmotors @24v
Power: Four 12v, 16Ah Hawkers
Motivation: Custom Made titanium tracks w/rubber strips on it for grip
Ground Clearance: 2mm
Turning Circle:0
Dimensions in CM: 1.38m x 0.74m x 0.70m
Weaponry: Pneumatic stinger powered by a 4€ bore, 12€™ stroke air cylinder at 200psi giving it about 2200 joules at end of swing
Self-Righter: The Stinger has a spike on top that pop out to self right the machine Strengths: Powerful weapon, good armour and speed
Weakness: exposed tracks from the back
sorry dont have any relies yet
What Paul means is to pick realies from the main wars, you dont have to had built them
indeed Ruark, pick whatever realie you want...
Paul?
