Page 9 of 18 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 175
Thread: Eye Of The Robot - Series 5
  1. #81
    Guest
    Dont worry Joey, this just makes it more fun when we beat him
  2. #82
    Yeah, I just feel like posting very technical reasons as to why things wont work
    I am trying to ignore him, its just very difficult...
  3. #83
  4. #84
    Guest
    This is my first time in a major by myself- my other major is Dual Duels, in which of course I am paired with Jamie. Im really excited (or dreading!!) to see how my vapours will fare all by them selves in a big major like this. Please dont do hypos Paul, we all know you can write brilliant battles and no one wants to see hypotheticals again
  5. #85
    I second that
    And were just waiting for Andy now...-2>Im trying not to say anything about Christmas 2077, but its hard...
  6. #86
    davids
    Guest
    When will people learn not to allow Andy to reserve spots as he takes forever to get around to posting actual stats.
  7. #87
  8. #88
    davids
    Guest
    Nah, I dont want to kick out Andy.
  9. #89
    You could always have 4 wheel drive in which the wheels where all at 90 degrees to each other, but then of course it would be horrible to steer normally...
  10. #90
    Stats to accomodate the CAD...
    Wedginator Devilution
    Shape: Wedge, sloped sides and rear. The rear is awkwardly sloped so that Wedginator always falls on its flipper when inverted. The wedge has slots in it for air intake and aerodynamics which help it move faster, and also they cool the motors down when moving.
    Colour: Alligator texture, with an evil face on the wedge and slightly overlapping the side panels.
    Speed: 16mph average, 35mph maximum. Can be locked at 15mph if needs be.
    Weight: 100kg
    Armour: 4mm Hardox with a 6mm polycarbonate baseplate. The skirts are 5mm titanium and the front barbs are 5mm Hardox.
    Drive: 2 LEM130 Lynch Motors @ 48v
    Power: 6 3600mAh NiCad Battlepacks @ 48v
    Motivation: 6WD, 15cm diameter aluminium hubs with urethane tire rubber for grip. The thing is that these wheels are cambered 60 degrees like Tazbot, so although its 6WD, it gives Wedginator a great ability to manoeuvre.
    Ground Clearance: 0mm at the front, 0mm at the side with skirts and 6mm without, and 10mm at the rear.
    Turning Circle: 0
    Dimensions in CM (LxWxH): 115 x 90 x 30
    Weaponry: A front-hinged flipper in a l l l shape on the front wedge, the bars are 5cm wide and are made of 1cm titanium. It is powered by 2 2kg CO2 tanks at 900psi and a 80mm stroke on the middle part. This should give Wedginator enough power to flip at least 1000kg away and still have enough after that first flip for about 29-34 more flips. Also there are barbs at the front to hold an opponent on the wedge quite securely.
    Srimech: The flipper. It rights Wedginator, not by simply tilting him, but swinging him into the air so he lands cat-like on his wheels.
    Strengths: Fast, very powerful, very manoeuvrable, powerful flipper, weapons synergy should work a lot.
    Notes: 7th incarnation, very demonic.
